1218 Views 1 Reply Latest reply: Sep 2, 2010 1:20 AM by Rowbi RSS
mattsetonend Just Startin' 6 posts since
Aug 22, 2010
Sep 2, 2010 1:14 AM
No sound audible when smallest buffer size/latency setting selected in Pod Farm 2.
I'm using the studio ux1 with podfarm 2.01. Everything seems to work fine, apart from when I select the 'Extra Small' buffer size in the hardware settings. When I select this, there is no sound from podfarm, nor from any other audio or videos etc, so I have to use the second smallest setting. There seems to be very little/no noticeable latency on the second smallest buffer setting, but it'd be nice to keep the buffer as small as possible! Everything is set to 44100 Hz/24 bit. I'm running Windows 7, Intel i5 core, 3.2 GHz. All other standard sound devices have been disabled. I've searched high and low for info on this to no avail, so can anyone out there tell me what the problem may be? Thanks...
  • Rowbi Expert Line 6 User 7,745 posts since
    Nov 25, 2006
    regardless of how powerful a PC is, there is an inherrent latency in all PCs.  if you can't get audio to pass at the lowest latency then your PC just can't copy with processing the audio that fast, so you'll have to stick to the next to lowest.
    that setting is designed to find the best for all the different models of PC (of which there's too many to count).  I've got a really fast workstation, but I can't use the lowest setting because my system can't cope with it.
    if you can't hear the latency, then stick with what works.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
