1 2 3 ... 9 Previous Next 28317 Views 120 Replies Latest reply: Apr 20, 2012 6:09 PM by amadeusperu RSS
StudioTM Just Startin' 135 posts since
Jan 30, 2007
Sep 7, 2010 10:45 AM
Pod HD 500 - HD400 - HD300 more info
Looks like you can buy Pod HD500 - HD400 - HD300 on this french page (se detailed pics attached below in this post)
http://www.distribution-music.fr/line-6-m-54.html?page=4&sort=2a
Google translation gave me this info on the HD 500
POD ® HD500 is a huge step forward in the field of modeling amplifiers. This is the only multi-effects pedal to offer 16 amp models Line 6 high-definition (HD), over 100 vintage and modern effects processors from the range M, and input / output analog and digital super complete.
The amp models are HD the new standard for modeling. They offer a gaming sensation, reaction, and interaction never reached. The realism is breathtaking and offers a quality gaming hitherto unparalleled
HD 16 amp models based on guitar sounds the most coveted in the world: California clean sounds, sounds from classic crunch, mesmerizing heat amps Custom saturation unbridled modern amps, and more ...
Over 100 effects: delay, modulation, distortion, compressors, equalizers, filters and reverbs. Up to 8 effects at the same time, tap tempo
512 user editable presets
Recorder / Player loops with 48 seconds footswitches for specific functions of cancellation, reading single configuration Pre / Post recording / overdub, stop / playback, playback speed and mid-Reverse
Built-in tuner with mute guitar signal
Outputs 6.35mm Jack and XLR (mono / stereo) MIDI In, Out / Thru, S / PDIF, USB LINK L6; effects loop (mono / stereo) Aux in Jack 6.35 mm; XLR microphone input with level control, headphone jack with 6.35 mm connector for Variax ® VDI, expression pedal input for external
Free software for editing and managing sound libraries
HD400
POD ® HD400 is a huge step forward in the field of modeling amplifiers. This is the only multi-effects pedal to offer 16 amp models Line 6 high-definition (HD) over 90 modern and vintage effects from the range of processors M and I / O analog and digital super complete.
HD 16 amp models based on guitar sounds the most coveted in the world: California clean sounds, sounds from classic crunch, mesmerizing heat amps Custom saturation unbridled modern amps, 128 user presets, 256 factory presets ...
Over 90 effects: delay, modulation, distortion, compressors, equalizers, filters and reverbs. Up to 4 effects at the same time, tap tempo
Recorder / Player loops with 24 seconds footswitches for specific functions of single reading configuration Pre / Post recording / overdub and stop / play
Outputs 6.35mm Jack and XLR (mono / stereo) USB MIDI, effects loop (mono / stereo) input for expression pedal external connector L6 LINK for full compatibility with the tube amps Line 6 range DT50 ™ and much more ...
HD300
POD ® HD300 is a huge step forward in the field of modeling amplifiers. This is the only multi-effects pedal to offer 16 amp models Line 6 high-definition (HD) over 80 modern and vintage effects from the range of processors M and I / O analog and digital full.
The amp models are HD the new standard for modeling. They offer a gaming sensation, reaction, and interaction never reached. The realism is breathtaking and offers a quality of play so far unmatched.
Over 80 effects: delay, modulation, distortion, compressors, equalizers, filters and reverbs. Up to 4 effects at the same time, tap tempo
Outputs 6.35mm Jack and XLR (mono / stereo) MIDI USB connector L6 LINK for full compatibility with tube amps from Line 6 line DT50 ™; MP3/CD input and much more ...
