2258 Views 10 Replies Latest reply: Jul 21, 2012 8:02 AM by inferno567890 RSS
TGun Just Startin' 4 posts since
Mar 22, 2007
Oct 12, 2010 12:41 PM
Strange Sounds in POD XT
Hello.
I have a POD XT, that I have used for many years now and I allways loved the sound it makes.
I Turned it of as usuall a few days ago. I woke up and went to play guitar using my POD XT, but when I turned it on like so many days and years befor I got a different sound from the same "tune" I played the day befor.
The sound had a "volume changer (volume goes up and down)" suddenly and the sound souded "thin". I tried some of the other tunes i use from the memorybank of POD XT but they were all messed up in one way or another, and they all was ruined. Everyone of the tunes have the same name and preset as the day befor, but the sound it makes now is just terrible...
I tried flashing the memory from my computer and that was successful, but the bad sound continued.
I tried not using it for 1 day, but the sound was still messed up.
I tried taking out the powercord, but the sound is still wrong.
How can I bring back the sound I allways had from my POD XT, and get rid of the strange "bug/ghost" in the POD XP?
Tommy G
  • Triryche Expert Line 6 User 3,698 posts since
    Feb 20, 2007
    Oct 12, 2010 1:10 PM (in response to TGun)
    Re: Strange Sounds in POD XT
    How are you montoring the PODxt?
    Did you try a new guitar cable?
    Did you have active pick-ups? If so, check/change the battery.
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    Oct 14, 2010 1:18 PM (in response to TGun)
    RE: Strange Sounds in POD XT
    I still cannot verify if there is a problem with the PODxt; if it just sounds different, or if it is not sounding as it should.
      Saying it sounds bad could mean that the settings have changed (for whatever reason) and just need to be adjusted.
      When re-installing the flash memory, are you making sure NOT to keep the existing patches and to let the update install new default presets?
      The only way to verify if there could be a problem is by checking with another POD set to the same settings and testing if they sound different than each other.
      Regards,
      Line6Hugo
    Apr 8, 2007
    Oct 14, 2010 4:57 PM (in response to TGun)
    Tgun,
      If it is no longer sounding how it should after re-installing the flash memory, you will need to determine if this is problem with the hardware or not.  Does it have a different sound, or does it have a bad sound.
      Either way, if it does not sound right after the re-installation of the flash memory and comparing with another PODxt (with the same flash memory version), you will need to take it to an authorized service center:
      http://line6.com/service_centers/
      Regards,
      Line6Hugo
    • slothrop Just Startin' 29 posts since
      Feb 27, 2007
      Oct 16, 2010 4:51 PM (in response to Line6Hugo)
      Re: RE: Strange Sounds in POD XT
      Hi, I'm having a similar problem with my PODxt, I have two guitars with active pickups that have been working for a couple years with the POD.  I recently plugged one in as usual and it  popped, crackled and sounded thin as the other user stated then the sound died completely, I tried the second active pickup guitar and the same thing happened.  I changed the batteries and tried different cables, unfortunately, I don't have an amp to try at the moment.  I am connected with USB and the pc is running windows7, I have not yet tried re-installing the software.
      I also have a guitar with passive pickups that works just fine through the POD.
  • inferno567890 Just Startin' 1 posts since
    Jul 18, 2012
    Jul 21, 2012 8:02 AM (in response to TGun)
    Hi
    I'm having exactly similar problem like TGun. the volume suddenly goes up and down, the tones got distorted and the tap button always blinks. I flashed memory through line 6 monkey but its still there. I've taken my pod xt to service centre, they have checked and confirmed its not a hardware prob and asked to check with line 6. Would be really grateful if you can help me out.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
