10174 Views 28 Replies Latest reply: Feb 2, 2013 2:11 AM by evand67 RSS
ncreed Just Startin' 25 posts since
Jul 27, 2007
Oct 16, 2010 5:40 PM
Weird noise in Pod HD 500
Has anyone else got a electronic harmonic with the 500. It is like a low volume octave that I hear between the note B to around G on the forth and third string in the 9th to 12th fret. It is on the Dr Z, both Voxes and the Deluxe. I haven't heard it on any other settings. This is with just the amp and no other effects on. I hope this isn't normal because I really like those models. Thanks for your help.
  • timowens Gear Head 1,230 posts since
    May 14, 2007
    Oct 16, 2010 6:14 PM (in response to ncreed)
    Re: Weird noise in Pod HD 500
    Could these be ghost notes? You can hear them in the X3 also, Line 6 claims that they are part of the actual amp that was modeled and that is why they are there.
        May 14, 2007
        Oct 16, 2010 6:24 PM (in response to ncreed)
        I don't have an HD but I do have an X3L and I've heard the ghost notes in it. Is it possible for you to post a sound clip?
      • ozbadman Gear Head 1,474 posts since
        Apr 17, 2008
        Oct 16, 2010 6:26 PM (in response to ncreed)
        I had some higher-pitched sounds in the X3L that I wasn't happy with, but didn't hear them until plugged into a P.A. I could barely detect them on headphones but on a P.A., it was shrill and horrible.
        Unfortunately, I only have headphones and a small Acoustic amp here. But, maybe you culd post an example setup, like Amp with its settings, and if you play, say, an A on the 6th string you here it. It might give us a better feel for what you're hearing and whether it's supposed to be there.
        Cheers,
        David.
      • Crusty_Old_Rocker Expert Line 6 User 3,096 posts since
        Jan 24, 2007
        Oct 16, 2010 11:33 PM (in response to ncreed)
        ncreed wrote:
        I didn't hear them in the X3. They are fairly loud. I hope they are not supposed to be there as it is distracting. Anyone else notice it.
        The are most definitely in the POD X3 and the PODxt.  Line 6 have always modelled all characteristics of the amps.
        Take a closer listen to the Vox and very early small Fender models like the deluxe and champ in the POD X3.  You'll hear them and there are many posts on the forum regarding the ghost notes modelled in the PODxt and POD X3 series devices.
        Cheers,
        Crusty
  • Singing_Heaven Just Startin' 37 posts since
    Aug 19, 2008
    Oct 16, 2010 8:16 PM (in response to ncreed)
    I wish you would post the sound sample...
    are you sure you aren't making harmonics with your palm as you play? a lot of times when gear and good speakers are introduced to the player they tend to hear things in their playing they miss when using headphones that muddy the sound at home because they are consumer and enhance the bass and high frequncies such as sony etc... once players are in good clean gear they start to hear the harmonics they may make without realizing when the palm is hovering the strings..
    just a thought anyway
    post a sound byte. I don't want to buy the hd500 if it might have some mathimatical errors somewhere in the models
    EDIT - low fret clearance? try another guitar as well to confirm.
    thanks for the info
  • cGil Just Startin' 393 posts since
    Jun 5, 2007
    Oct 16, 2010 10:57 PM (in response to ncreed)
    Ghost notes?     Fresh caps that haven't "formed" (burn-in is 100hrs on Sozo caps, for example) can sound pretty nasty, too; almost as bad as a fresh speaker, as they both do nastiness to the high end.   But both are obvious nasties.   Ghost notes are kinda tricky, and it means there's gotta be some seriously good ears hanging around this place to catch ghost notes!  Not to mention a seriously accurate modeler to pull it off!
    So they modeled amps with poor filtering (Dr. Z) or just plain worn out and/or drifted below spec power supply filter caps?   Oh great!  And ya know that's just SO easy to fix with a quality cap swap.     But what they hey, if Dr. Z does it on purpose, and those things DO sell for a pretty penny, who'm I to judge.  Right?
    Anyway, since the genuine article of the fugly odd harmonic ghost notes typically happen when power tubes (with poor PS filtering) are cranked way up, try turning the gain or preamp of the model down just a hair, or till the power amp half of the model stops with the spooky biz.   I'd be all over this right now, if I only had my HD500 to investigate it.   And oh how I'm hating GC right now for making me wait.  Tuesday isn't soon enough cuz all these zircon encrusted, golden ear'd tone details have me swimmin' in seriously deep drool already.   Arrrgh.
    Gil...
      Aug 19, 2008
      Oct 17, 2010 4:13 AM (in response to cGil)
      Well I can confirm after reading the other thread and listening to the ghost sample that my X3 does have them and they can definitley bugger up a harmony you may be working on. From a search on Google I have found that these ghost notes happen in amps with power supplies that are weaker and this create the unwanted secondary note. The example posted in the other thread is a very clean tone and the second note is almost as loud as the guitar note.
      I found a post in another modeller forum and they stated they don't use amps that have ghost notes in them to model as they consider the amp to be faulty and they repair the power supplies in any amp to ensure there is no ghosting in their modellers...
      So how many amps are we talking about here that have these bugger second notes? I would think that these older amps would be listened to enough to ensure these uncontrolled secondary notes would be non existant. I know people claim this adds charactre to an amp but listen to the sample mp3 and you can hear that is adds a second note that is uncontrolled and out of key for many projects...
      this could explain why some amps sounded muddy on some tunes? something to look for when tracking I guess. ahh well I still love my x3 and the HD when it comes...
    Jan 24, 2007
    Oct 16, 2010 11:31 PM (in response to ncreed)
    The ghost notes actually contribute to the authentic sound.  I have played a lot of Vox AC30s and some original Fender Deluxe amps and those under tones are definitely in there and are part of the character of those amps.
    Cheers,
    Crusty
  • phil_m Expert Line 6 User 4,243 posts since
    Jan 25, 2007
    Oct 17, 2010 2:06 PM (in response to ncreed)
    Could this be result of having the wrong setting for the AC frequency parameter described on page 2-4 of the advanced user's guide?
    AC Frequency (Knob 3): The HD Amp Models within POD HD500 include simulation of AC hum typical of the AC Vacuum Tube Heater component, which is an important part of the tonality of a tube amplifier. We’ve provided the option here to set the AC Rate to match that of the USA (60Hz) or UK (50Hz) frequency for authenticity. (This setting may be subtle depending on the current Amp Model settings, and may be more apparent when synchronizing this setting with the AC rate of any tube amplifier that POD HD500 may be plugged into.)
    • philGre Just Startin' 35 posts since
      May 9, 2010
      Oct 18, 2010 12:58 PM (in response to ncreed)
      I had the same as you yesterday on a J-45 when putting some drive and even more with an overdrive (tube screamer) in front
      I'm on 50hz setting, (and 50hz power supply), listening through headphones. I did not try to change anything, but it sounded rather bad indeed, harmonics not aligned with the note. I noticed the level of these harmonics vary a bit with microphone selected, certainly because some emphasize the frequency where the note happens.
      I heard it the most around 12th fret and 3 first strings, but also below, though less noticeable.
      Looking forward to see any answer to this, might be a future firmware, who knows...
      Cheers
      Philippe
        • harmaes Just Startin' 90 posts since
          Feb 20, 2009
          Oct 19, 2010 2:26 AM (in response to ncreed)
          I have had the exact same experience. This fizzyness made me return the HD500 within the period of 14 days.
          I liked the responsiveness and dynamics on the HD but this noise becomes very annoying.
          I've decided to stick with the X3L and wait until these issues get ironed out.
            Feb 20, 2009
            Oct 19, 2010 2:39 AM (in response to harmaes)
            I can hear this fizzyness also in here: http://www.youtube.com/watch?v=D-C7TbcEglY
            • DrugDM Just Startin' 1 posts since
              Jun 2, 2006
              Oct 19, 2010 9:01 AM (in response to harmaes)
              Hello. I have am a new owner of the HD 500 and experienced the same problem. I recently read a post that discussed putting the noise gate in the front of the chain and that solved my problem.  For some reason if you put the noise gate after the amp it appears to be less effective than at the beginning of the signal chain which is not what you would expect if you would use a traditional set-up.  Hope this helps.
                May 9, 2010
                Oct 19, 2010 1:31 PM (in response to DrugDM)
                just a stupid idea : I noticed this "ghost note" came mostly on 3rd string and above 12th string, and started to wonder if it could noy be linked to a bad harmonics setting on the guitar?
                If the effect depends so strongly on the place where you play it, that could make sense (I did not get the same ghost note playing for instance 4 frames below on 2nd string though playing the same notes...
                what do you think guys?
                regarding the fact to go for a replacement, well, I'm not sure it could be linked to a bad model given the number we see, I'd rather see this harmonics story or a firmware update to fix that (IMHO)
                  Feb 20, 2009
                  Oct 19, 2010 11:04 PM (in response to philGre)
                  These are not ghost notes IMO. I had the issue with my Variax 700 on the HD500 but it does not occur with the X3L.  I would love a reply from the users who've had the HD for a while/as beta tester. Do you also hear this fizzy, rattly sound. A good trial is a twin reverb: with the drive to 0 I don't hear it, turn it slightly up it starts to appear. This is very noticeable with headphones. Btw, I don't have the HD anymore so can't make any test with it.
  • frenchfries Just Startin' 71 posts since
    Jan 28, 2007
    Oct 20, 2010 11:26 PM (in response to ncreed)
    It might be digital aliasing. I've owned a dozen of modelers until now and each of them (regardless of its brand) was/is able to produce digital aliasing in some cases. It's an embedded part of the digital stuff, exactly like hiss and hum are linked to the analog world. :-)
    • Mooseboy08 Just Startin' 7 posts since
      Dec 17, 2010
      Jan 3, 2011 4:00 AM (in response to frenchfries)
      Wow, am I ever glad that I found this post!
      I'm a new HD400 user and I noticed this same problem. It occurs for me when I get close to A440, and to my ears, it sounds like digital aliasing. I'll be following this thread with great interest.
    • evand67 Just Startin' 5 posts since
      Dec 28, 2008
      Feb 2, 2013 2:11 AM (in response to frenchfries)
      Yeah,....I love the pod tones, have had everything from the first bean to the xt to the x3 and now the hd500...it's gotten better, but on certain amps,(dr z, ac 30 mainly)  the aliasing comes out really bad...I only notice it on high notes,..but it's enough to drive you batty...but,..I just try to stick to patches that seem to do better....the plexi tone is great,..there's a tiny bit of it,..but it's negligible...when it gets really audible, it sucks...you can get it with digital delay units too..it's the worst...but, I still love the pod...it's the only way to play at night and not wake the neighbors!!...I have never tried axe fx..I wonder if they have solved this problem?...I'd almost spend the money on it if that was the case....but I'd imagine it has aliasing too...
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
