Oct 19, 2010 11:23 AM
FBV express lights and pedal problem
Like (0)
I have a FBVexpressMK11. The four A-D pedals, work for changing ,the channels,but the tuner and volume wah pedal does not work. The tuner lights flash on when first turned on ,but that is all .Is this ,a software problem,or is this a component problem.
Hello,
Have you updated the firmware on the pedal? Have you calibrated the pedal?
If not, here is some documentation that will help you do that:
http://line6.com/community/docs/DOC-1652
http://line6.com/community/docs/DOC-4501
Line6Miller
I have reinstalled all the updates you suggested,and have recalibrated as shown on the web site. It done just as it was supposed to to calibrate,but the pedal lights still do not work,nor does the tuner function, or pedal for wah and volume. Thanks for all of your help.
Daleg1940,
If you updated the pedal and attempted to calibrate, but the problem persists, there must be a hardware problem with the FBV. You should contact our service department for a replacement if you purchased it new from an authorized Line 6 dealer within one year:
(818) 575-3600
Regards,
Line6Hugo
Thank you for all of your help.I bought this from Musiciansfriendas may need repair or replacement,so I dont belive there is any waranty.I appreciate all of your help you have given to me.I will have to buy a new one to replace this one
