1964 Views 7 Replies Latest reply: Jan 23, 2013 12:02 PM by rjryerson RSS
amesbahi Just Startin' 3 posts since
Oct 20, 2010
Oct 20, 2010 2:05 PM
Turning off effects
Is there a way to turn off the effects instead of turning the effects knobs all the way in each direction once?
    Mar 26, 2007
    Oct 21, 2010 3:12 AM (in response to amesbahi)
    Re: Turning off effects
    For the Spider IV 13 and 30 models, no, but once all the FX are off you can save the channel defaults in this position.  For the Spider 75 and up models, you would simply set the various FX to the OFF position on a per preset basis and then save the modified preset.
    Nick
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Oct 21, 2010 3:57 PM (in response to amesbahi)
    Re: RE: Turning off effects
      To save, press the Amp Model/Channel button and hold down 3-5 seconds until the light flashes. So, let's say you've dialed in the sound of the "Clean" channel to your liking. Press and hold the "Clean" button until you see it blink.
      Next time you switch back to Clean, it should be the same sound settings you last saved it as.
      Effects can only be turned off by turning the knob(s) fully to the left, or "Off" position.
      Regards,
      L6Perry
  • bled500 Just Startin' 1 posts since
    Dec 22, 2010
    Oct 19, 2012 5:33 PM (in response to amesbahi)
    hi! i just wanted to be clear. does the effects button that turns the fx off or you have to hold the channel for each ch amp type? clean, crunch, insaine.. i have a lv 75 spider and each chanall automaticly has some type. how can iturn the efx off so i can change channels w/out efx on them? no f-board etc, just able to go up an down chs w/out any efx. hope this makes sence, thank.
    • fflbrgst Power User 1,292 posts since
      Mar 6, 2011
      Oct 22, 2012 8:37 AM (in response to bled500)
      bled500 - you need to save the sounds (without FX) into user patches.  When you mention 'clean, crunch, insane...' - these are manual sound settings on the Spider IV 75, you cannot save new sounds to these manual settings, instead you have to save them into user patch locations.
  • rjryerson Just Startin' 8 posts since
    Mar 11, 2011
    Jan 23, 2013 12:02 PM (in response to amesbahi)
    I realize this is a old thread, but I want to chime in here for future readers; just so they don't think Line 6 is overly complicated or something.
    To easily turn on or turn off the associated effects, you only need to hook up an FBV Shortboard MkII. There are buttons for each effect, in addition to channel buttons.
    For instance, you can control (on off) the stomp, modulation, delay, and / or the reverb of each bank. Now, to change amp models (clean red to crunch green), you would have to use multiple tone banks but that makes sense.
    I don't think this would work with any amp that does not have sound banks.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
