11219 Views 20 Replies Latest reply: Feb 17, 2013 9:27 AM by rmaginnis RSS
tbeardmore Just Startin' 3 posts since
Jan 18, 2008
Oct 21, 2010 7:16 AM
Factory reset for HD500
Isn't there a factory reset for the HD 500...???
NEED HELP!! Thanks
I know about the
[Video Tutorial] How to Reset the POD HD by updating or reinstalling the Flash Memory
http://line6.com/community/docs/DOC-2057
and there is a Factory Reset for the 300 and 500
[Video Tutorial] POD HD300 / 400 Factory Reset
http://line6.com/community/docs/DOC-2043
I also found this on the topic......
Factory Reset HD500? in        POD HD Oct 8, 2010        by evilbert420
I don't see how to factory reset the HD500. Is the only way to re-flash via USB and tell it not to save the presets?
Tags: hd500 factory reset pod
Re: POD HD 500 Crashed. Please Help. in        POD HD Oct 13, 2010        by nickmattocks
I suspect the HD500 factory reset procedure I used early in the beta test no longer works.  I read a post  - I think from Line6Miller the other day as I recall- that said there  was no factory reset procedure for the HD500 except to flash the unit. That being the (probable) case you're a bit stuck if your unit won't accept the update properly Nick
  • ricksox UberGuru 11,600 posts since
    Mar 28, 2006
    Oct 21, 2010 8:36 AM (in response to tbeardmore)
    Re: Factory reset for HD500
    The only way to reset the POD HD500 is to reinstall the flash memory via Line 6 Monkey software.
    Line6Miller
  • johandovelius Just Startin' 9 posts since
    Aug 9, 2006
    Dec 6, 2010 12:57 PM (in response to tbeardmore)
    Wouldn't it be easy for Line 6 to just offer a downloadable bundle with all the presets? As you can save all current presets as a bundle and save or share it, it would be great to get all the presets as a bundle, and save on the computer. Practically, it is four setlists. It's of course to late for me, as I have tweaked some of the factory presets. I thought I could recall them anytime. I guess a lot of us users have done the same.
    Is there anywhere a bundle could be posted? Maybe somewhere in the Customtone area?
  • glen_mcenroe Just Startin' 2 posts since
    Jul 5, 2012
    Nov 6, 2012 7:05 AM (in response to tbeardmore)
    Some one please help i seem to have a problem
    My pod hd 500 seems to be no working when i plug on my adapter to the pod the main screen shows line 6 but keeps on blinking away and does not go on the the present screen someone please help .
    • jimsreynolds Power User 2,227 posts since
      Jun 27, 43450
      Nov 6, 2012 10:23 AM (in response to glen_mcenroe)
      Glen
      Try a global settings reset:  hold down the 'right' button on the directional keypad and power up the Pod.   This does a global settings reset and can help.  It is also useful if the preset you were working with was corrupt as it jumps you back to patch 1A.  If you use this, you will need to check your global settings to make sure they are how you want them.  You will also need to recalibrate your expression pedal (details here --> http://line6.com/support/docs/DOC-2223).  None of your homemade presets will be lost but your setlist names will be renamed to the default names.
      If the global reset does not clear it then you can try a safe mode reset.  This time be ready with your PC and USB cable.  Now hold down the 'left' button on the directional keypad and power up the pod.   Connect the USB cable and use Line 6 Monkey to flash-update the firmware on the POD.  Make sure you choose not to overwrite exisiting presets.
      As a final thing, if the previous thing fails, repeat the previous process but this time hold down the 'down' button on the directional keypad and power up the pod..  This is a deeper level of safe mode.
      In each case:
      1)  Power off
      2)  Hold down the button and then ...
      3)  Power on
      4)  wait a few seconds then release the button
      Links
      • preciousgeorge Just Startin' 27 posts since
        Sep 17, 2012
        Nov 10, 2012 11:59 AM (in response to jimsreynolds)
        Holding the LEFT nav pad key while powering up does the Global Settings Reset.  (Not the right nav key...right key takes you to Test Mode where you'd peform the pedal calibration required after the Global Settings Reset).
        1 caution is performing a Global Settings Reset will change all your set list names back to the factory names.  Lucily all your stored presets (within your set lists) are unaffected.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
