Currently Being ModeratedOct 22, 2010 12:01 PM (in response to kicasso)Re: Want to have all presets setup w/input 1 as GUIT+AUX+VARX CH1 and input 2 as MIC - do I really need to change each one manually or is there a global way I can do this?
the input settings are always on a per patch basis... if you are building your patches from scratch... you can simply make your changes and copy that patch to all the other locations as a starting point...
if you want to apply it to the presets etc... i'm afraid you're out of luck.
- Report Abuse
Like (0)
Currently Being ModeratedOct 22, 2010 12:37 PM (in response to TheRealZap)Re: Want to have all presets setup w/input 1 as GUIT+AUX+VARX CH1 and input 2 as MIC - do I really need to change each one manually or is there a global way I can do this?
Also, you can copy groups of patches as well as complete setlists. So, if you're starting from scratch, create one patch. Copy that. Copy both those. Copy all 4. Copy all 8. Copy 16. Copy 32. Now just copy complete setlist into the other 7 slots. SHould be pretty quick overall.
David.
- Report Abuse
Like (0)
Currently Being ModeratedOct 22, 2010 1:59 PM (in response to kicasso)Re: Want to have all presets setup w/input 1 as GUIT+AUX+VARX CH1 and input 2 as MIC - do I really need to change each one manually or is there a global way I can do this?
i think you will find what you search in the "utility" setting, in the page 7 i think, you just have to make "variax enabled"...try and tell us
- Report Abuse
Like (0)
Actions
- Retrieving data ...
Legend
- Correct Answers - 5 points
- Helpful Answers - 3 points
About
Follow
Subscribe
