4540 Views 24 Replies Latest reply: Feb 18, 2013 3:47 PM by Akeron RSS
tommy1170 Just Startin' 51 posts since
May 7, 2006
Nov 2, 2010 9:05 PM
HELP - My New POD HD 500 Sounds Terrible!!!!
OK - So I just purchased the POD HD500 and it sound horrible.  I have to have something set incorrectly.  I am using the unbalanced outs connected to the effects loop return of my Vetta II Head using a Y-Cable.  The cable is brand new and I know it works as I tested it on the Vetta with another effects unit and it was fine.  Here is my current setup:
  1. I have the amp setup in ComboAmp mode and have tried both the "pre" and "full" models on the HD500.
  2. I am using a Charvel USA with Duncan JB pickups - input 1 is set to Guitar, Input 2 is set to Same.  Input pad is at normal
  3. I am still trying to find out exactly how things should be routed in the HD500 to get a good metal tone.
Can anybody guess what I am doing wrong?  My sounds are all crappy, woofy and there is DEFINITELY some sort of brittle clipping going on.  I have tried lowering the master volume.  I just don't get it.
Thanks-
A so far VERY disappointed Tom.
  • FrozenOzone Just Startin' 175 posts since
    Oct 12, 2010
    Nov 2, 2010 10:14 PM (in response to tommy1170)
    Re: HELP - My New POD HD 500 Sounds Terrible!!!!
    I am/was having a hard time too. I did manage to configure a patch tonight that might do with a little tweaking. This is my first attempt to build a patch on this thing. I will upload the tone. It's called Hardy Beef Tone.  I doubt it will fix your problem but it's worth a shot.  I am going straight from the balanced mono 1/4" to a power amp in to a 4x12 cab.  I have pad set not normal.  I also have it set to line.  I tried the the XLR outs and wasn't satisfied with my sound. It sounded weak so I switched to the 1/4". Now I am getting a better sound.
    Message was edited by: FrozenOzone
    • ozbadman Gear Head 1,474 posts since
      Apr 17, 2008
      Nov 2, 2010 10:31 PM (in response to FrozenOzone)
      A few people have had some initial problems but mostly, they've got sorted out after a while so hopefully this'll end well for you.
      My advice when getting things set up initially is to start with clean sounds. This helps eliminate distortions caused by poor setup, rather than distortions you want for your 'sound'.
      Set up a patch with either no amp, or a Fender Deluxe, and nothing else. Personally, I'd start with no Amp. There should be no distortion of your signal with this setup. In my opinion, these HD500's are very sensitive to hot pickups. I would start by turning the +PAD on, or winding down your guitar volume. If the signal is distortion free at that point, then you have a reference point. My guess is that turning on the +PAD is probably enough, provided your output  gain from the HD is not overpowering your input stage to your real amp (ie: the master volume isn't too high, as you said).
      Let us know how that goes and we can take it from there.
      David.
  • whiteop Just Startin' 415 posts since
    Dec 5, 2009
    Nov 2, 2010 10:52 PM (in response to tommy1170)
    one little switch that's on top of your board  that drasticallly changes your tone is the 1/4 Out. Make sure it's set to Line. Makes the whole difference in the world and often overlooked by the newbies.
      Apr 17, 2008
      Nov 2, 2010 11:28 PM (in response to whiteop)
      The 1/4" out switch itself shouldn't change the tone. It changes the overall output volume from Line Level to "Amp" level. Line level is louder than amp level. It only affects the tone if you happen to be overdriving the input stage of your amp when on Line output. That being said, you may well be overdriving your input stage of your amp in this case, although for test purposes, turning down the Master Volume would have the same effect.
      The take-away is that it's a level switch, not a tone switch, but may well be the source of your problem.
      Cheers,
      David.
    Mar 26, 2007
    Nov 2, 2010 11:50 PM (in response to tommy1170)
    Tom
    Some very good pointers from the guys who've replied so far.
    To add to what's already been said, I would suggest the following:
    First, update the HD500's firmware to the latest (v1.1) - EVEN if 1.1 is already installed!  Let's just make certain that it is installed correctly and that, like them or not, you can get a decent sound from some of the factory presets - when the update procedure asks if you want to retain your presets answer NO (Note your custom presets if you have any you want to keep will be lost, so you may want to backe these up using HD500 Edit before you start).
    The firmware on your POD at delivery is almost certainly a pre-launch version and the nature of pre-launch firmware is that tweaks may be still have been being made to the final firmware that was available by launch date.  The likellihood with pre-launch firmware installed at the factory is that some amp models may not yet have been fully optimised, so consider firmware v1.1 as the current optimum version and anything before that may show variable results.
    OK - once you've got a clean updated system and you're on a level playing field, set the Output options to Studio/Direct and plug in just a pair of reasonable or good quality headphones to assess how the HD500 sounds through them.
    Assuming all sounds reasonably OK, then the next stage is to set the Output options to Combo Power Amp, and connect both the Left and Right 1/4" outputs to the Left and Right FX Loop Returns on your Vetta - make sure you have a dummy 1/4" jack into the input of your Vetta.  I don't think you should be using a 'Y' adapter if your amp has stereo FX returns - and to my mind that might be where the sound is being summed somehow out of phase leading to the nastiness you're hearing.
    Turn the Master volume on your Vetta to a moderately low to medium setting so as not to blow the roof off.
    Turn the Master Volume on the HD500 to about 12:00
    Set the Guitar in switch on the HD500 to Normal
    Set the 1/4" switch on the HD500 to Line Out
    The factory presets - unless they are heavily effected as some are, should at least sound OK through the Vetta.  If they sound really bad, then compare how they sound through headphones again and if there is a major difference (there will of course be some difference because headphones aren't speakers), then you need to try a different amp with your HD500 just to rule out the Vetta as a possible cause.  If that produces the same horrible sound, then you may have a faulty HD500, ad so you may want to go back to where you bought it and have them audition the HD500 and check it out against another one.   There's no way unless you design a patch to sound really nasty deliberately, that your HD500 should ever sound completely terrible as you seem to be describing.
    HTH
    Regards
    Nick
  • Brion_Kean Just Startin' 391 posts since
    Dec 27, 2007
    Nov 3, 2010 7:31 AM (in response to tommy1170)
    Check the "programmibility" portion of the Vetta head. Also, what's going on with the Y cable? Try sending a single mono 1/4" from the L POD output to the mono / L FX return of the Vetta. Make sure the Vetta is not processing that signal at all.
    Do the firmware update that Nick mentioned.
    Make sure the Output is set to match / studio / whatever that's called, instead of the combo / stack modes (to start with)
    Basically, doing that, tweak with the line/amp setting, and take a look at what the Vetta is doing to the line in / fx return (is there an dB boost or cut, or any unintentional processing happening?)
    I say use single 1/4" mono to eliminate the possibility of phase cancellation.
  • Andy_Mack Just Startin' 49 posts since
    Aug 13, 2007
    Nov 3, 2010 7:42 AM (in response to tommy1170)
    I certainly don't have it all figured out yet.....but I've found a pretty quick method for getting my sounds tweaked.
    I move the looper to the "pre" position, and then I record some playing.  After I've got something recorded, I just let the loop play over and over, and while it's doing that I can tweak some settings and hear the result instantly.  This has helped me tremendously in the "tone-crafting" department.  Maybe this would help you too....
    In fact, when I first turned on my POD HD, I was very unhappy with the crunch to metal type sounds, but I'm getting happier each day.
    Good luck,
    Andy
  • rublalup Just Startin' 97 posts since
    Jan 4, 2008
    Nov 3, 2010 1:07 PM (in response to tommy1170)
    this may be dumb, but be sure to check all the Outputs modes... i guess, if youre running into a head effects return, you should start with the Stack Power Amp  mode and not combo amp as you mentioned.
    Also, why are you using a Y cable? i dont get that...
  • Karl_Houseknecht Expert Line 6 User 3,732 posts since
    Jan 25, 2007
    Nov 3, 2010 1:23 PM (in response to tommy1170)
    Why would you do this?  The unbalanced outs can be mono if you only run out of either one.  If you need stereo on the Vetta return, then just run two cables, one from each output.
  • MickSlick Just Startin' 71 posts since
    Apr 5, 2007
    Nov 16, 2010 3:12 PM (in response to tommy1170)
    I hear you on the boost option, I started another thread on no ability for  a basic clean boost with the 500, sure you can try using comp. fx, eq's etc... but they all color the sound and are unnecessarily complicated to get a simple clean boost.
  • jreichow Just Startin' 22 posts since
    Oct 8, 2006
    Nov 17, 2010 5:35 PM (in response to tommy1170)
    Here is my two and a half cents. I just purchased an HD500 a week ago. I have been using line6 since the beginning, so I am no stranger to their gear and limitations. I have had the original kidney, XT Live, X3 Live and UX-8. The HD500 sound quality is horrible. It is the most brittle thin sounding box I have ever owned, and I am a fan of Line6 boxes for what they are. I have spent 3 days trying to get one patch to sound even half as good as my X3. This box is a big dissapointment. The only reason I keep trying to make this thing work is because of the assignable footswitches and FX, and FX loop. The effect parameter editing access is unusable even in a studio situation. By the time I get to the parameter I want I forgot what the heck I was doing. I couldn't imagine playing out with this thing. The real crime here is that this box just washes out when you try to mix it with anything. It either sounds a million miles away or so thin you wish it would get away. Severely dissapointed!!!!!
    My advice is to take the thing back like I'm going to do. Get yourself an X3.
      Apr 17, 2008
      Nov 17, 2010 5:40 PM (in response to jreichow)
      Hey jreichow,
      Are you a metal player? I play mostly rock and cleaner stuff, and sold my X3L because it's not even in the same ballpark as the HD500. However, for metal players, this may or may not be the case as I don't play metal I'm, not able to say. If you're not a metal player though, the HD500 is SOOOOO much better than the X3L.
      my 2c,
      David.
      Mar 26, 2007
      Nov 17, 2010 5:49 PM (in response to jreichow)
      Hi
      That doesn't sound right at all.  There's no way the HD500 should sound in any way brittle or thin.  To me the HD500 has way more body than the XTL or X3L both of which I still have.  I don't like the X3L into any guitar amp - it takes way too long to tweak an acceptable sound out of it BUT straight to desk it's great.  To me something is not riight with your HD500 or what you're playing it through.  the obvious things are to check your output settings are right for whatever you're connected to and also perhaps to re-flash the firmware to the latest version/  i know that sounds like a stock answeer and to some extent it is, but often works.
      Editing at the unit is far more intuitive than the XTL or X3L are for me, but everyone has different preferences.
      If you can't get your particular unit sounding good, I'd seriously consider A/B'ing it against another one if you can as you may just have a faulty unit.
      Nick
  • Iknowathingortwo 1,667 posts since
    Jul 17, 2007
    Dec 24, 2011 1:11 PM (in response to tommy1170)
    All new patches uploaded to CustomTone.  Something weird happened previously where all patches were the same.  This should no longer be the case.
    Many of my favorites creations I've posted from everything from Acoustic guitars to classic clean and heavy electric tones for both 6 and 12-string guitars.
    Hope they are useful to any who might check them out.  You can also go directly to them by searching under my ID.
    Happy Holidays to all!!
    Neal
  • amalia_91 Just Startin' 4 posts since
    Sep 21, 2008
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
