2746 Views 13 Replies Latest reply: Mar 8, 2011 9:52 AM by Line6Hugo RSS
hoodcreeper Just Startin' 66 posts since
Aug 3, 2010
Nov 12, 2010 9:41 AM
Trouble recording direct.  Low volumes and Breakup??
Recently purchased new HD 500.  I admitadly have limited experience with multi effect boards.  My problem is when going direct from pedal into mbox then into pro tools I have lower volumes and harsh breakup in the form of distored excessive signals.  This occurs in 1/4" mono and stereo outs as well as the xlr outs.  I have the pedal setup to studio output mode.  Yet I have to turn up to excessive amp model volumes as well as drive settings to obtain midtone volumes.  The left and right mixer volumes are set to excessively high too.
When I play exclusively through the pedal on my own through the headphones jack then HD 500 sounds great.  Beefy with a full tone and full sound.  When I plug into recording situation with friends then sound quality goes away.  I should elaborate on the mbox>protools set up as the whole band is listening through a headphone hub split from output of mbox.  However everyone else sounds full and rich except the poor HD 500.
What else can I try???
  • ozbadman Gear Head 1,474 posts since
    Apr 17, 2008
    My first suggestion would be to plug the HD500 into something else as a test. If it sounds good through the headphones, it should at least get close through something else. Just to make sure the issue isn't being introduced by protools, try plugging the HD500 1/4" or XLR into a normal amp, or stereo, or whatever you can find. This will prove the problem is on the HD500 side, and we (that is, you with the help from people on this board) can go from there.
    David.
    • FrozenOzone Just Startin' 175 posts since
      Oct 12, 2010
      hoodcreeper.
      I have high powered humbuckers and only experienced the break up on the factory defaults.  If you create your own patches or get some from the customtone website http://line6.com/customtone/ I think you will have a better experience with your unit.  Theres almost 300 patches ready for download.  Here is my setup and it sounds great:
      Guitars:
      PRS Tremonti SE
      Dimarzio Super Distortion bridge
      Dimarzio LiquiFire neck
      Ibanez SZ320
      Dimarzio PAF Pro neck.
      Power Amp:
      Beheringer EuroPower EP1500
      Cabs:
      4 X 12 B-52
      Kustom KPC12MP 12" Powered Floor Monitor
      Apr 17, 2008
      Hey hood,
      Well, the fact that it sounds fine through other amps and into garageband (presumably also all using the 1.4") means it's not the HD500. It's the protools setup. It sounds like you're probably under or overdriving the soundcard input into protools. The softness implies underdriving. Turning up would give you a poor quality signal, with a lot of white noise due to poor s/n (signal to noise) ratio. Having said that, the output from the 1/4" plugs is a decent volume. Have you tried plugging your guitar directly into protools (without the HD500). I suspect that'll will also sound bad. You could try the line/amp switch on the HD500, but essentially, it doesn't sound like the problem has anything to do with the HD500 at all.
      Try plugging the guitar in directly and let us know the results of that.
      David.
    • spaceatl Expert Line 6 User 4,456 posts since
      Jan 24, 2007
      If you friend is using ProTools then you will have to use the ProTools interface...Have you tried the SPDIF? Might make sense to take out the DA conversion and just let the HD500 hit the ProTools interface digital...Seems like your friends interface would have an SPDIF...That would actually take out the DAD conversion that is going on if your are using the HD500 analog outs...
      One thing you could do as a test...take a TRS 1/4 to (2) mono 1/4 cable and run the headphone out into the interface...headphone level stuff is fine for line level inputs...that will tell you a lot like if the inputs on the interface are set to -20 when they should be +4...that sorta thing...
  • ricksox UberGuru 11,600 posts since
    Mar 28, 2006
    Out of curiosity, did you check your tone panning within your patches? Not sure if that would have had an impact but it's something to check.
      Line6Miller
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    Not sure why it was so low.  I recommend panning the tones to the center or adding a COMP effect with the gain turned up to increase the volume output.  Perhaps connecting the POD's outputs into instrument level inputs on your interface would help as well.
      Regards,
      Line6Hugo
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
