1 2 3 ... 10 Previous Next 16591 Views 139 Replies Latest reply: Feb 5, 2013 4:19 AM by RonMarton RSS
jacoby75 Just Startin' 11 posts since
Nov 22, 2010
Nov 22, 2010 6:59 PM
Relay G50 signal dropout
Hi all,
I purchased a G50 for my bass guitar a few months ago, and have been really impressed with the tone and features of the unit.  I love no longer having to worry about tripping over my cable, and the sound is great as well.
I am having one problem, though, which upon reviewing the boards I see others have experienced.  I have a random, intermittent signal loss.  At the risk of repeating what others have said, here's the problem:  Througout a 4 hour set, it sounds perfect 99% of the time.  However, anywhere from 1x per night to 1x per set, I have a random signal loss for about half a second or a second.  The bass just cuts out, and then comes right back in.  There seems to be no rhyme or reason to when it happens.  I could be as close as 5-6 feet from the receiver, or 30-50 feet away.  It can be with brand new or older batteries.  I also have two different 1/4" to trs cables that I have used with it (the factory one, and one that came with a Shure system), and it happens with both cables.  It doesn't seem to be worse with one cable over the other.  When it happens, I'm not close enough to my amp to see the lights on the receiver to know if any of the green lights went out, or turned red, but by the time I notice the drop out and get back to the amp, the sound is back and the lights appear normal.  It also happens irregardless of what channel I'm on, having experienced it on at least a couple of channels.  Regarding signal strength, I always have 3 full green bars on the receiver.  I don't think I've ever seen it lower, and I've never seen red lights in signal strength.  The bass just cuts out and then comes right back.  I have wiggled the cables on both ends, and it doesn't seem to have anything to do with the connection from either the bass to the transmitter or the receiver to the amp.  It's just a random signal loss.
Ultimately, maybe it's not that big of a deal for the average person, but being a full-time musician in a touring band, it's a pretty big deal to me.  It makes me look really bad when the bass just quits working multiple times per night.  Reliability is very important to me when I'm on the road, so I want to know if there's anything I can do to help this situation.  Again, there seems to be no rhyme or reason as to when it happens that I can discern, and no warning.  It just cuts out and then comes back.
Reading some of the responses in other posts, I can answer some of the questions you may ask:
1.  Yes, I usually have my cell phone in my pocket while I play.
2.  I have the receiver sitting on top of my amp rack, which is an SKB rack case (molded plastic with metal railings) and of course metal components inside, as close as the top rock space.
-are you saying those 2 factors will affect the reliability of the signal?  I saw that question asked a few times but never saw a definitive answer.  If that is the case, would that mean if I leave the cell phone somewhere else and maybe set my receiver on the floor it would help?
3.  I've never been looking at the signal strength bars when it happens, so I don't know if there's a change, but by the time I get back to the amp to check, it shows 3 solid green bars, always.
4.  I can be anywhere from 5 feet to 50 feet away when it happens.
5.  Happens with both fresh or older batteries
6.  I am using the factory power supply.
Thanks a lot,
Rick
  • dboomer Line 6 Support 1,997 posts since
    Oct 13, 2008
    1. Nov 23, 2010 9:22 AM (in response to jacoby75)
    Re: Relay G50 signal dropout
    Hi Rick
    Cell phones do not cause dropouts nor do they cause audio interference to Relay.  Cell phones may get into your instrument or cable and then since they become part of your signal  they would go throught the Relay, but Relay will not pick it up in the radio.
    There is always a chance of overloading a receiver if you get the transmitter too close to a receiver.  Usually 5 feet away is a safe distance.  Have you tried setting the transmitter to low power.  I know it seems intautively wrong to set it to low ... but radios always work better if the tranmitter and the antennas do not have too much power.
    The green LEDs will go out on the receiver if the signal mutes, so if the green LEDs stay on and the signal drops it is not the radio having the problem.  Usually in this case it is because the jack into the guitar or into the receiver is a bit loose.
    The metal rings on your case are only a problem in the antennas come within about 1 inch of them (or actually touch them).  Do you ever find yourself near big metal when you play?  For example leaning up against something like a refridgerator or a metal garage door would cause the system to mute.
    Generally having the antennas up in the air works better than on the floor ... as this helps line of sight issues.  Do you splay the antennas at a 45 degree angle?  This helps with polarization.
    Is the beltpack on your strap or in your pocket?  It will perform much better on your strap.  Does your strap have any metal in it?
    Without being there in person it is hard to diagnose the problem.  It is possible that you have a hardware issue, but not likely.  It is more likely that you have a line of sight issue when the unit mutes.
    Oct 13, 2008
    3. Nov 23, 2010 3:01 PM (in response to jacoby75)
    WRT #4 (and for anybody listening in)
    Large metal objects cause reflections of radio waves and distortion of the information in them.  This is a physics issue and affects all radios (not just ours).  I'm guessing someone would have great difficulty playing with any wireless in the boy's locker room.  It's like echo to a sound system.  they just don't mix well.  You don't have to actually touch anything.  If you get close enough to a big enough steel girder you will likely have problems.
  • bob4us Just Startin' 20 posts since
    Aug 16, 2010
    4. Nov 27, 2010 3:52 AM (in response to dboomer)
    Does the two antenna should perform a "diversity" reception just to avoid reflections effects?
    I used for 10 years a Nady UHF diversity analog system without any dropout,
    Now with G90 I'm entusiast of the sound but I'm experiencing a similar problem on stage, rare but very upsetting: one or two drop outs per session with full battery charge, 3 meter distance.
    I'm a little warried because if it's a firmware bug there's no way to upgrade it from an external port.
    Bob
    Oct 13, 2008
    6. Dec 10, 2010 2:15 PM (in response to jacoby75)
    Glad it's working.  You can switch to Low Power on the G50 or G90 if you need to be close.  I just read info from one of our competitor's website and they recommend a 10 foot minimum distance.
    Working with radios is a bit like working with speakers.  They may sound great at 5 or 10 feet, but not so pleasant if you stick your ear right up to one.
    Oct 13, 2008
    8. Feb 2, 2011 8:35 AM (in response to jacoby75)
    You should call our service department and get the hardware checked out ... 818.575.3600
  • cyberwally2000 Just Startin' 5 posts since
    Mar 31, 2007
    10. Feb 5, 2011 11:50 AM (in response to jacoby75)
    Hi my name is Walt, and  I just purchased a Relay G50 unit.  I must say that at first I was quite impressed with the sound but alas I'm also experiencing random signal drop out.  I've used it with different guitars and amps and it happens when you least expect it.   In the manual  line 6 talks about putting power on High and checking that the unit is in the lock mode, did this but still have random dropouts less then before I must admit.  Any ideas? Take care.
    Mar 31, 2007
    12. Feb 5, 2011 2:16 PM (in response to jacoby75)
    Hey Rick , thanks for your quick reply.  Please let me know if there is any info on their part to solve this problem.  By the way did you try locking your system, this is what I read on the troubleshooting section of the manual.  Yet still this doesn't convince me, let's see what Line 6 comes up.  Thanks again ,  Walt
  • rsto10 Just Startin' 27 posts since
    Apr 22, 2009
    14. Feb 5, 2011 6:51 PM (in response to jacoby75)
    I also have a G50 with signal dropout.  Have tried everything you have listed above and nothing makes it better.  Originally, I was blaming it on my Line6 amp, but after playing a few gigs with a cable (and feeling like a dog on a leash) I had no dropouts.  Please keep us posted on what you find out.  I think I'll be sending mine in soon as well.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
