Dec 1, 2010 2:01 PM
Connect Spider IV HD 150 to Pc by FBV shortboard
Like (0)
hi, i had a problem, i don't now how to connect my spider IV hd 150 W to my pc for download line 6's programs.
I found explain only for FBV MkII models, but i had a FBV shortboard!
thx for your attention and sorry for my bad english
Hi
The FBV MkI boards will not work as they have no USB connectivity.
You need either an FBV MkII Shortboard or the less expensive and less capable FBV MkII Express to achive connectivity with a computer.
Regards
Nick
Even if I use MIDI cables?
Sorry. Spider IV doesn't have MIDI, nor do the FBV pedal boards. Spider Valve MkII does have MIDI
Nick
ah ok sorry!
Last question, if I use Ethernet cable? spider line 6 150 W hd had an ethernet exit!
Hi
Several Line 6 devices use an ethernet cable to connect them together BUT it is NOT an ethernet connection or protocol that Line 6 uses. Line 6 uses a proprietary communications protocol. You cannot directly connect any Line 6 device to a computer using the connections that are made using RJ-45 sockets/ plugs and ethernet cables. NEVER plug a Line 6 device into your computer's network ports. You will almost certainly damage one or both devices ![]()
Nick
