1575 Views 9 Replies Latest reply: May 18, 2011 8:49 AM by johnpicton RSS
hrodmusic Just Startin' 16 posts since
Mar 3, 2010
Dec 1, 2010 10:20 PM
Recording Via USB problem
ok so i just bought my pod hd500 i upgraded from the toneport gx, and i have a question! soo when i try to record via usb the signal is really low, i have the volume set all the way on the pod, volume and master and its still the same! what is going how do i fix it?
  • cu2day Just Startin' 5 posts since
    Aug 4, 2006
    Dec 15, 2010 7:44 PM (in response to hrodmusic)
    Re: Recording Via USB problem
    I have that exact same problem and am also wondering what the solution is.
  • olerabbit Just Startin' 105 posts since
    Jan 3, 2007
    Dec 15, 2010 10:31 PM (in response to hrodmusic)
    Do you record into a MAC? If yes this is a known issue especially with 64 bit systems.
    There are some threads reportiing this problem.
  • songwaters Just Startin' 107 posts since
    Oct 4, 2010
    Dec 16, 2010 12:12 AM (in response to hrodmusic)
    The master vlume is independent of the USB volume.
    there are the 4 things you can try:
    1)increase the channel volume up from 0Db in the mixer blocek to the maximum possible for both chanells without recution in recorded sound quality.
    2)increase the amp volume
    3)increase the distortion stomp's volume(if its there in your chain)
    4)increase the input volume of your DAW for the selected chanell
    FYI, I too feel the USB volume at 0db mixer level for clean patches is a bit low.
  • Ibanezs5470 Just Startin' 4 posts since
    Apr 11, 2011
    May 18, 2011 4:03 AM (in response to hrodmusic)
    I have a problem with USB while recording in Windows XP- My POD HD  500  is up to date and my system is stable. Everything seems to be ok,  but  after I enter the tuner and I press exit, ( It doesn't matter if i  do  this with the knobs or pedals ) the communication between the  computer  and my POD sucks... and after that my computer can't playback or   receive audio, and I must turn off my laptop, and the pod hd and  reboot.....
    My driver is the latest version....
    So i am a  little bit angry, because I can't do  recording...PLEASE HELP!!!!!!!!!!!
