430 Views 1 Reply Latest reply: Dec 9, 2012 8:01 AM by lousygarua RSS
ybeylin Just Startin' 1 posts since
Dec 9, 2010
Dec 11, 2010 11:09 AM
Safely removing POD UX1
Hey there
I've been  wondering, what is the safe way to discconect my POD?
The  'Safely remove hardware' button wont work and disabaling the POD from the "printers and devices' doesnt work either(when I plug the pod back in it wont connect if I use this way)
Just plugging it out seems to cause crashes some times
so...what is the safe way to discconcet it?
  • lousygarua Just Startin' 2 posts since
    Nov 8, 2007
    Dec 9, 2012 8:01 AM (in response to ybeylin)
    Re: Safely removing POD UX1
    bump from 2010
    I own the older TonePort GX. With GearBox, it worked like a charm. I could disconnect the USB cable without even shutting down GearBox. But now with PodFarm 2.5, I can't be as joyful disconnecting cables as I used to be. If I fail to turn off PodFarm and my sequencer, disconnecting the USB cable will halt the system (Windows 7 64-bit). Sometimes, even after closing the mentioned programs, disconnecting the cable just kills the world.
