3656 Views 7 Replies Latest reply: Mar 31, 2012 9:29 PM by samuelito2011 RSS
aeugle Just Startin' 111 posts since
Sep 5, 2008
Dec 23, 2010 12:36 AM
How to connect a POD HD 500 to a Marshall MG 100 DFX
hello support team hello community
I have a problem / question,
I bought a HD 500 and it is areally cool device. The sounds are very nice if I use the HD 500 with a headphone. My amp is a Marshall 100 DFX. If I connect the HD500 in any way to the amp the sounds especially the clean ones are not good.
Do you have any experience with this combination?
What is your advice regarding connection?
HD500 -> Marshall: Clean channel -> Output setting: Combo front?
HD500 -> Marshall: Effect loop in -> Output setting: Combo power amp?
HD500 -> Marshall: Clean channel -> Output setting: studio
HD500 -> Marshall: Effect loop in -> Output setting: studio
Shall i use any cabinet simulation or turn this off?
Regards and thanks in advance
Thomas
  • Rowbi Expert Line 6 User 7,745 posts since
    Nov 25, 2006
    Dec 23, 2010 12:35 AM (in response to aeugle)
    Re: How to connect a POD HD 500 to a Marshall MG 100 DFX
    obviously different amps sound different, so some amps may reproduce the HD500#s tones better than others.
    I would suggest you may get the best results using one of the following, in my order of preference.
    HD500 -> Marshall: MP3/CD input -> Output setting: studio
    also try the full and preamp tones.  my head is telling me that the full tones would be best, but just try the preamp ones. you may find something you like.
    Mar 26, 2007
    Dec 23, 2010 12:38 AM (in response to aeugle)
    Hi
    I have just looked up the specification on your amp.  It appears to have a parallel FX loop which in itself isn't suitable but with Marshall amps, this often means that the loop has a control pot that when turned up to 100% makes it a serial FX loop.  If this is the case with your amp, then i would recommend feeding the output from one of the 1/4" outputs on your HD500 into the FX loop return, turn the mix control for the FX loop all the way up and set the output mode on the HD500 to Combo Pwr Amp.
    Marshall amps already have a very distinctive tone of their own and this can either work for you or against you when using any POD in my experience, so you may have to experiment a little more than you would if going straight to PA.
    Your amp's tone controls should have no bearing at this stage on how the amp's tone is, but knowing Marshall (I have four different Marshall amps and one of them is set up in such a way as the tone stack does affect the tone of whatever is fed in via it's FX return) the tone stack controls might affect the amp's tone, in which case you should try to set everything as neutrally as possible by having all tone controls set to about 50% on the amp
    Make sure the Amp/Line switch to the left of the expression pedal on the HD500 is set to Line.
    You might find that using PRE amp models in the HD500 will give you better results.  Experiment too with turning off cab modelling in the POD on a per preset basis.  Experiment with adjusting the type of Mic on the cab model in the POD and also adjust the ER control
    IF the FX loop method above doesn't work, then you have to use the main guitar input.
    Set all tone controls on the amp to 50% as a starting point, set the Amp/Line switch on the POD to Amp, set the POD output mode to Combo Front, and set the amp to the cleanest channel with its gain control set to the cleanest setting it can manage.
    Make sure the POD is running the latest firmware version 1.1.
    Regards
    Nick
  • sandman69 Just Startin' 50 posts since
    Jul 31, 2009
    Dec 23, 2010 10:26 AM (in response to aeugle)
    I have used my HD500 with my Marshall TSL100 head some.  I believe they are configured similiarly in regard to loops.
    You should definitely plug into the effects return.
    None of the controls for any of the amp's channel will change anything with the tone, since they are all preamp controls.
    On mine the only thing that is used is the FX Mix for that effects loop.  It becomes the amps volume in this configuration.
    I turn it up just a little to get volume at home, and if I put Mix all the way to max my houses windows start shaking!
    Also, on mine I think I had to plug a cable plug into the effects send to get it to function.  Though that was a week ago so I will have to check when I get home to be certain.  Seemed to be some sort of bypass if nothing is inserted into it.  It was just a 4" patch cable with nothing connected to the other end.
    This is one reason I am going with a Rack poweramp to use to push the speakers.  Seems like a waste to use the Marshall for this.
    Anyway, I plan on selling it and put some funds together to get a new Variax!!!
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
