2456 Views 14 Replies Latest reply: Jan 20, 2011 9:13 PM by bcappnyc RSS
guitarman7 Just Startin' 11 posts since
Jun 15, 2010
Jan 8, 2011 11:50 AM
Flash Memory Update Failure
I tried to do the flash memory update for the HD 400 today.  It failed twice, now there is nothing on my POD and when I re-opened the Monkey it just has a question mark and won't let me try the update again?
Help!
Thanks,
Mark
  • Rowbi Expert Line 6 User 7,745 posts since
    Nov 25, 2006
    Jan 8, 2011 1:06 PM (in response to guitarman7)
    Re: Flash Memory Update Failure
    reset your pod by holding the channel a footswitch while powering it on.  follow the on screen instructions to carry out the factory reset, then try to update again.
    hopefully you follow best practice (i.e. whenever you update anything, take a backup of everything you wouldn't want to lose) and you had a backup of your custom tones, as the reset will wipe them all out.
  • spaceatl Expert Line 6 User 4,456 posts since
    Jan 24, 2007
    Jan 10, 2011 4:01 PM (in response to guitarman7)
    You need to reflash it...with success...
    You can bring the HD400 up in safe mode the same way you do for a reset...
    • Power up holding A.
    • connect the USB cable
    • start the monkey and try to flash it.
    If it isn't coming up correctly in the Monkey, kick off the driver install from Monkey, unplug the HD400 USB and follow the driver install prompts...Once the driver is in, you should be able to flash...I would suggest that you avoid installing the driver again in the all in one installs of Edit and Monkey....
    • Dezaxxx Just Startin' 3 posts since
      Dec 26, 2010
      Jan 12, 2011 6:23 PM (in response to spaceatl)
      Big thanks for your solution spaceatl! You saved my mental health...
        Jan 24, 2007
        Jan 13, 2011 1:07 AM (in response to guitarman7)
        sounds like the driver is whacked...have tried other USB ports on the pc?
          • trpoh Just Startin' 1 posts since
            Oct 15, 2010
            Jan 17, 2011 3:31 PM (in response to guitarman7)
            Hi
            Per O. from Norway. For your mental healt care....
            I try to update my Pod300 with the flash 1.20 as well, and the same happens to me. "please wait" and not function.
            Seems to be some bugs in this update. I am not able to pass it over 100% restore neighter, so the updating 1.20, seems to stop the prosess before foot pedal calibration be possible. look forward to some answers from the Line6 people. Let me know if some phone numbers somming up.
            BR PerO.
    • dp500 Just Startin' 2 posts since
      Nov 14, 2010
      Jan 20, 2011 4:02 AM (in response to spaceatl)
      Thanyou spaceatl. This worked perfectly on my HD300. Now time to JAM!
  • ZackDolore Just Startin' 1 posts since
    Dec 15, 2008
    Jan 17, 2011 6:26 PM (in response to guitarman7)
    I had the same problem today but could solve it quickly thanks to guitarman7's solution! Worked perfectly!
    However, I believe I found the underlying problem to have been that I used the front-USB for the first (and unsuccessful) try of updating the Pod. Once connected to the "original" USB-ports in the back of my PC, the update was easy as pie. Ehhr... with a little help of my friends! ;-) (thumbs up, bro! You saved my day!)
    So make sure you DO NOT USE THE FRONT-USB before you go on with guitarman7's suggestion ("Power up holding [footswitch] A; connect the USB cable; start the monkey and try to flash it") to make sure it works.
    Good luck y'all!
    Zack
      • bcappnyc Just Startin' 1 posts since
        Jan 19, 2011
        Jan 20, 2011 9:13 PM (in response to guitarman7)
        I had the same problem where the screen would just say "please wait" forever, even after a factory reset. All you have to do it connect it to your pc with the monkey, select the firmware section and hit "rollback". This will do a rollback to v1.1 (which takes like 10 minutes) after which you can reinstall v1.2 (which takes like 20 minutes). All of my presets were deleted but you can find the factory bundle download by searching in the forums. problem solved
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
