1069 Views 8 Replies Latest reply: Feb 21, 2013 2:21 PM by RonMarton RSS
SouthportSDC Just Startin' 26 posts since
Nov 19, 2010
Jan 24, 2011 8:10 AM
V70 Rx contrast
Hi Don,
Is there anway to adjust the display contrast on a V70 Rx ?
The contrast is very low so the display is allmost unreadable, the backlight brightness is OK.
Thanks
  • dboomer Line 6 Support 1,997 posts since
    Oct 13, 2008
    Jan 24, 2011 9:36 AM (in response to SouthportSDC)
    Re: V70 Rx contrast
    Unfortunately there is no adjustment possible.  It is controlled by the hardware.
        Oct 13, 2008
        Jan 24, 2011 11:28 AM (in response to SouthportSDC)
        Re: V70 Rx contrast
        No ... it is fixed
        • cfortner Just Startin' 8 posts since
          Jul 6, 2010
          Feb 18, 2013 4:45 AM (in response to dboomer)
          Re: V70 Rx contrast
          I own a XD-V75 and the contras first was fine. After using it for firmware-updates for several Relay G50 + G90 suddenly the contrast became such bad, that the display is unusable.
          Is it a hardware-fault or a feature? I programmed it once with the actual Firmware 2.0 - no contrast anyway...
          Whats to do?
          Thanks
          Christian
          • RonMarton Iknowathingortwo 357 posts since
            Jan 12, 2012
            Feb 18, 2013 10:32 AM (in response to cfortner)
            Re: V70 Rx contrast
            G'day from Australia, Christian...
            Sadly, (as indicated, I think, by the earlier part of this conversation) it would appear that your LCD display has suffered some kind of hardware "melt-down" that can only be repaired by the unit being serviced in the workshop of your nearest Line 6 Service Center.
            You could create a "Support Ticket" by clicking through a series of links, starting with a click on "Support" in the black area at the bottom of this page, ...however, I think may well be easier for you to go via the dealer that sold you the unit.
              Jul 6, 2010
              Feb 21, 2013 12:55 PM (in response to RonMarton)
              Re: V70 Rx contrast
              I've found the fault:
              I used another than the original power supply. Same voltage, but... with the original power supply, all works fine!
              Bye
              Christian
                Oct 13, 2008
                Feb 21, 2013 1:03 PM (in response to cfortner)
                Re: V70 Rx contrast
                Thanks Christian for reporting back.
                Funny things happen when the XDV's are starved for current.  You would expect just plain failure, but they start to work normally and then go haywire.
                Jan 12, 2012
                Feb 21, 2013 2:21 PM (in response to cfortner)
                Re: V70 Rx contrast
                ...And it's prompted another thought regarding LCDs.
                Here in Oz, we're often faced with the failure of LCD displays (on all sorts of gear) belonging to folks who've left them exposed to the heat from direct sunlight.
                A good "rough guide": If the black metal of your equipment is becoming warm from the sun, cover it up or (better still) move it into the shade ...and slap some 30+ sunscreen on your own exposed "bits".
                As for current "starvation", I've found that it pays to allow half an amp (500mA) of ripple-free and fully regulated 9 volts DC for each XD-V receiver, be that supply from "wall warts" or marine/auto DC to DC "power conditioning" converters, ...exactly as Don says.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
