2697 Views 14 Replies Latest reply: Nov 17, 2011 1:34 PM by bobadler RSS
rickk6 Just Startin' 15 posts since
Aug 17, 2010
Feb 2, 2011 1:50 PM
SD Card
Spider Jam's "Erase SD-Card Recording" does not work.  Says there is "No Rec in Line 6 Folder" even though I do have recordings on the card and have downloaded them on my computer.  The only way I can clear the SD-Card is to Format it.  I  was advised to reinstall my Flash Memory (2.09 Firmware) due to cracking noises on recordings.  I downloaded the 2.09 version (which I already had in my Jam) and transfered it to my SD-Card.  When ready to install in Jam I get a message that says "Firmware not found in Root Directory" although I do have it on my SD-Card.  How do I fix this?  Could I have a bad SD-Card?
  • Buy-a-Fender Iknowathingortwo 426 posts since
    Jul 25, 2008
    Feb 2, 2011 2:06 PM (in response to rickk6)
    Re: SD Card
        Jul 25, 2008
        Feb 2, 2011 2:23 PM (in response to rickk6)
        Re: SD Card
        have you tried formatting the card with the Spider Jam?
        from the Advanced User Guide:
        It’s best to start out with a new 1 GB or 2 GB SD card. If you have an existing card, that’ll work fine, but make sure you’ve backed up any saved files on the card first, because when you format your card, all your files will be erased. The main reason to format your SD card is to ensure your card is set up with the JM4 filing system. It’s also a good way to get a fresh start in organizing your sessions. To format your SD card, follow these steps:
        Insert an SD card (up to 2 GB) into the SD card slot on the Spider Jam rear panel.•
        Press the •
        SAVE
        button; you’ll see a list of menu items in the LCD.
        Turn the wheel and navigate to •
        Format Card
        , then press the R Arrow to format.
        Press the Up Arrow to confirm "•
        Yes
        ". The format process will take a few seconds.
          Jul 25, 2008
          Feb 2, 2011 2:27 PM (in response to Buy-a-Fender)
          Re: SD Card
          if you are trying to reinstall FW.BIN make sure ther eis absolutely nothing else on the card
          Once that is done then reforamt the card with it in the SJ
          That should make a folder on the SD card where the recordings will be placed. It almost sounds like your recording are getting on the card but not where the SJ wants them to be
          If all else fails hang on until Joe chimes in here and see what he has to say
            Jul 25, 2008
            Feb 2, 2011 3:13 PM (in response to rickk6)
            Re: SD Card
            sounds like you're doing all the right stuff
            have you tried a different SD card?
  • joegillespie Gear Head 795 posts since
    Mar 31, 2007
    Feb 2, 2011 3:19 PM (in response to rickk6)
    Re: SD Card
    The Spider Jam is very fussy about the brand and size of SD cards. I have not had problems with any brands but I do know some people who have. A SanDisk 2Gb card always seems to work. Sometimes, you need to run the formatting procedure multiple times (10 is not unusual). Then you copy the FW.BIN file to the SD card and run the MD5 Checksum utility on the file on the card to make sure that no corruption has taken place.
    Anyway, to address your first problem, not being able to erase files. If the files you copied from your computer (into a LINE6 directory) on the SD are not of the correct spec, the Spider Jam will not recognize them
    WAV, Mono, 16bits, 44.1Khz. If you have stereo WAV files or MP3s, it will not work. Also you have to be aware of the 8.3 filenaming convention used in FAT16 file system, for example, SDCARD\LINE6\FILENAME.WAV is a legitimate path SDCARD\SOMEOTHERFILENAME.WAV is not.
    Jan 27, 2010
    Feb 3, 2011 3:29 PM (in response to rickk6)
    RE: SD Card
      Sorry to hear that you are having so many problems updating the Spider Jam.
      The card that we use in the lab is a Sandisk 2GB SD card like this one:
      http://www.amazon.com/SanDisk-Standard-Memory-Canon-PowerShot/dp/tech-data/B000VR1TGQ
      Thanks,
      David
      Line 6 Customer Support
  • bobadler Just Startin' 3 posts since
    Sep 21, 2011
    Nov 17, 2011 1:21 PM (in response to rickk6)
    Re: SD Card
    What a bunch of crap. Does it really need to be this hard to get a stupid SD to work.
      Dec 22, 2006
      Nov 17, 2011 1:23 PM (in response to bobadler)
      Re: SD Card
      this is your first post... we have no idea how hard its been for you....
      why don't you start your own post and then we can help make it easy for you....
    Sep 21, 2011
    Nov 17, 2011 1:34 PM (in response to rickk6)
    Re: SD Card
    With all do respect I dont have to start my on post, my problems are exactly the same a countless others on this board. I have spent this afternoon trying all the remedies that the fine folks on this forum have suggested, to no avail.
    What I cant figure out is, clearly this problem exists through multiple equipment platforms and has now for quite awhile. Why has Line6 not been able to come up with a clear remedy to these problems. Better yet why were these products released in the first place.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
