1502 Views 10 Replies Latest reply: Dec 29, 2012 12:17 PM by silverhead RSS
timsim Just Startin' 3 posts since
Jan 11, 2008
Feb 11, 2011 10:47 AM
pod x3 reverb problem!!!
My pod x3 has a problem with the reverb, it keeps truning on, even when it's set off. When it comes on by it's self and you push the reverb button off, it goes off and them ramdanly comes back on, very, very annoying. This pod is in pristine condition, and only used in my house and never never taken out.
  • lowsco Iknowathingortwo 263 posts since
    Nov 7, 2006
    Feb 11, 2011 11:52 AM (in response to timsim)
    Re: pod x3 reverb problem!!!
    This will be related to the Reverb potentiometer. As you probably know, even when the Reverb is switched off, turning the Reverb pot slightly switches it back on. The pots can be very sensible, so I'd say make sure the X3 doesn't move or try to avoid any physical impact on the unit.
        Dec 22, 2006
        Feb 11, 2011 12:05 PM (in response to timsim)
        vibrations can be enough...
        try parking the reverb knob in the off position except when editing...
        your tone will still recall your reverb settings.
          • timowens Gear Head 1,230 posts since
            May 14, 2007
            Feb 11, 2011 2:48 PM (in response to timsim)
            Even without any vibration, it's still a possibility. Just as a sanity check, try working the reverb knob from minimum to maximum several times and than leave it parked at the minimum position.
            • edstar1960 Iknowathingortwo 712 posts since
              May 25, 2010
              Feb 12, 2011 8:23 AM (in response to timowens)
              +1
              Yes - I agree - the most likely cause of your problem is that your VERB control knob is set to a value above zero and the X3L mistakenly picks that value up as an override every time you use it - this is a common enough problem reported for other values controlled by the knobs on the front panel - they are extremely sensitive and the slightest vibration causes the X3L to go into dynamic override mode and use whatever value the control knobs are set to rather than what is recalled by the patch. The only way to avoid this is to have them all parked at zero.
              So please try setting the REVERB control pot to zero and leave it there.
              Does that fix your problem?
            Dec 22, 2006
            Feb 11, 2011 3:23 PM (in response to timsim)
            you are missing MY point... sound *IS* vibration... if you can hear the sound coming out of it... then there is vibration...
            whats it hurt to try first, and call us stupid later....
  • customtoyz Just Startin' 1 posts since
    Jun 1, 2008
    Dec 26, 2012 3:33 PM (in response to timsim)
    did anybody find a solution for this problem? i am having the same problem with the reverb, it comes on randomly and i have tryed save setting every way i now how and it will still come on by it self.
  • affluence Just Startin' 1 posts since
    Oct 20, 2006
    Dec 29, 2012 11:52 AM (in response to timsim)
    I absolutely have this problem to. Even in dead silence. Its not "vibrations". I noticed it only tends to happen when I've got some sort of digital connection. When I'm straight analog this doesn't happen. Its ruined so many takes I can't even believe it. I feel like its getting a signal to turn on the reverb from another device when connected digitally.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
