4183 Views 7 Replies Latest reply: Apr 23, 2009 9:42 AM by Jimmahbee RSS
Jimmahbee Just Startin' 4 posts since
Feb 27, 2009
Apr 22, 2009 1:20 PM
Trying to record pod 2.0 midi?
I'm trying to record my pod 2.0 through midi and when I go to the sound editor it works fine bu through my midiman midisport I get nothing. I'm recording in Reaper and it recognises the interface just no midi!
  • Rowbi Expert Line 6 User 7,745 posts since
    Nov 25, 2006
    Apr 22, 2009 1:29 PM (in response to Jimmahbee)
    Re: Trying to record pod 2.0 midi?
    what exactly are you trying to record??  is it the MIDI program changes that you want to record?  have you asked on the reaper forum how to setup reaper to record that??
    just in case... if you're trying to record actual audio over MIDI, then you can't.  MIDI doesn't carry audio, it carry's control information about MIDI devices, but not actual audio.
    • jackkate Just Startin' 40 posts since
      Mar 22, 2007
      Apr 23, 2009 8:50 AM (in response to Jimmahbee)
      Sorry if I wasn't being clear -
      The POD 2.0 does not convert your guitar audio to midi, so you can't record note information via midi.
      The midi on the POD 2.0 is only for patch parameters and patch changes, not for note data.
      Hope that helps....
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    Apr 23, 2009 9:22 AM (in response to Jimmahbee)
    Jim,
    If anything, Reaper will record the parameter changes you make on the POD while recording, such as changing the EQ and Drive parameters on the face of the POD or selecting an effect, but it will not receive MIDI note information that you play through the POD with your guitar. The POD will NOT convert the audio you play through it into MIDI note messages and send it via MIDI out.
    Regards,
    Line6Hugo
    Please make sure to award points to helpful & correct responses to your questions.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
