3533 Views 11 Replies Latest reply: Aug 14, 2012 10:42 AM by Haz_07 RSS
metalsir Just Startin' 6 posts since
Mar 15, 2011
Mar 17, 2011 8:57 AM
PocketPod & wah
hi,
i'm a new "pk pod" user.. i have few questions for you amazyng people.. =)
1) is possible storing the wah settings on the pod? or i can use the wah only with my pod connected to the pc with the
vyzex on?
2) if not, some of you can explain me if there is any setting to get a similar sound (i mean of my presets with the wah switched on) using ONLY the pod (not connected to the vyzex)?
really tks a lot, i hope someone can help me.. becouse without this feature the pod is unuseful for my way of playing..
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    Mar 28, 2011 9:02 AM (in response to metalsir)
    RE: PocketPod & wah
    Metalsir,
      The wah can only be enabled and controlled in the Vyzex software and CANNOT be accessed with out being connected to that program.  You can save your settings to a preset on the POD so that you can use it without being connected to the POD, but you will not be able to control or edit the wah parameters outside that program.
      Regards,
      Line6Hugo
    • kuser Just Startin' 2 posts since
      Mar 12, 2011
      Mar 28, 2011 12:08 PM (in response to Line6Hugo)
      Re: RE: PocketPod & wah
      On board there are several contacts H1 ... Is it possible for them to solder connector Wah pedal but where to get the wiring diagram can from POD2.0
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Mar 28, 2011 2:45 PM (in response to metalsir)
    The only way to do what you're trying to do with your POCKET POD in a "live" situation is to use an actual Wah Pedal between the guitar and the POCKET POD. There's no way to control wah parameters with a POCKET POD. While you can do this via software control (when recording or practicing at home), for live scenarios you're going to need an external Wah Pedal.
    There's no way around that, sorry man.
    Dec 26, 2007
    Mar 29, 2011 10:43 AM (in response to metalsir)
    Yes, I tried several tests. While you can get a "fixed-position" Wah setting when the Vyzex software editor is running and the USB is connected, there's no way to "save" that state into the memory of the POCKET POD such that after you disconnect the device and use it standalone that it will have the Wah fixed-position active.
    Sorry, man. It doesn't do this. Only our larger POD's (PODxt, POD X3) have this capability. You'll need an actual Wah pedal in front of the unit to accomplish what you're trying to do live.
    Mar 12, 2011
    Mar 29, 2011 1:11 PM (in response to metalsir)
    Re: PocketPod & wah
    Save the 2 files. l6t with WAH = ON and WAH = ON. Compare the contents of 2 files. They are the same. Hence the switch is not saved or loaded. Need to be updated. Sorry for my English.
    • PsicraftTony Iknowathingortwo 243 posts since
      Jun 22, 2007
      Mar 29, 2011 1:48 PM (in response to kuser)
      Re: PocketPod & wah
      As Line6Perry says and as you guys noted, PocketPOD does not store the Wah state inside the preset dump - The Vyzex editor 'could' fake around this by storing your wah state elsewhere in the bank file and then send the correct CC to turn it on when each preset was loaded but there would be the following issues:
      1. Without the editor (and computer) connected this wouldn't happen - You'd be back to the No Wah situation
      2. If you re-uploaded the sounds from PocketPOD into the editor all the wah settings would be lost.
      So really, the editor can't add wah position storage because at the heart of it PocketPOD (like POD 2.0 before it) does not actually store your Wah position.
      PODxt and the later PODs on the other hand... Well they do this an a lot more...
      Cheers,
      Tony
  • Haz_07 Just Startin' 1 posts since
    May 9, 2009
    Aug 14, 2012 10:42 AM (in response to metalsir)
    Re: PocketPod & wah
    I bet there is a way of updating the software of the pocket pod so that it is able to store wah settings....
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
