3543 Views 23 Replies Latest reply: Dec 7, 2012 11:56 AM by ym5432 RSS
jpoprock Just Startin' 59 posts since
Sep 2, 2006
Mar 22, 2011 12:11 PM
HD500: PA vs Studio Direct... a baseline?
Hey guys! I'm going to be soundchecking my tones thru the house PA at church tonight. It's a big church and a big PA. But I don't know what to expect from it. I've dialied in some tones that I like, and have played them via the studio out and headphones, as well as changing it to a Stack/Power Amp to reference thru my stereo 4x12 (in both stereo and mono too). The thing is, I don't have a GOB of confidence in our FOH guys. It depends on who it is. But
You'd think that if it sounds good via Studio Out, and it sounds good via Stack/Pwr Amp, that it would sound good thru the house. But does the burden to adjust fall on me, or the FOH guy? I shouldn't have to have some sort of "compensation reference" in my head when dialing in tones at home. If it sounds killer, then it should sound pretty killer thru the house right? I always hate it when you find that your awesome tone sounds like a chainsaw thru the FOH, or has way too much gain (less is more, I know), or high end, etc. My question is... is there anyway to establish a pretty good baseline for whether your tones are good or not? Because if I show up tonight early and soundcheck my tones... and find that they are WAY off from what it sounds like outfront... that will really throw me for a loop. I'm ok with making some adjusments. But doesn't it really fall on the sound guy to make his adjustments to get it sound right?
I mean, Lincoln Brewster has his tones dialed with his X3. You'd think that he gives it to him as he wants them, and makes THEM dial it in. He shouldn't have to constantly "guess" as to what will sound good. If it is good, then it should be good. I don't want to end up with "tones for church, and tones for everything else" if I can avoid it, because I won't truly know if they will sound good until I try it... which takes all the fun out of constructing sounds at home.
I guess I won't know until I hear the characteristics of the PA and room. But it would be nice to have an idea before hand! I've spent hours crafting the types of tones and sounds that I will likely use, and I would hate it if they were way off the mark. I'd be surprised. But I expect it, so there ya go. It's my luck.
Also, I'm assuming that I'll be feeding the PA mono. So, for Dual Amp tones.. the unit doesn't make those mono do they? It seems like when I tested this thru my 4x12 mono, only one of the two amps were there. I guess that means I'll have to change the panning to both be out of the Left side, right? Will this make stereo delays sound funny too? I'd have to think that it would. So I avoid stereo patches.
I guess I'll let you know how the soundcheck goes and what I discover. Should be interesting.
  • hitchface Just Startin' 334 posts since
    Jul 1, 2007
    Mar 22, 2011 12:16 PM (in response to jpoprock)
    Re: HD500: PA vs Studio Direct... a baseline?
    Going from headphones to PA has been a major disappointment for most folks who have tried. Unless you've got nice, flat studio headphones, it won't even be close.
    Linc used a global EQ (AFAIK) that he would tweak from venue to venue.
        Jul 1, 2007
        Mar 22, 2011 12:40 PM (in response to jpoprock)
        As Far As I Know.
        And yeah, I know it probably wasn't what you wanted to hear. Generally people are using consumer headphones to create patches. Consumer 'phones give you a smiley-faced frequency curve, so when they mix for it and go to PA, all of a sudden they've got this honky, SUPER midrangey and very flatulent tone. Because the PA is ideally flat, people wind up over-compensating for the headphone sound and get a mess of a sound.
        Just be prepped to tweak the EQ. The heart of your town should remain. Keep in mind the Fletcher Munson curve and you'll be golden.
  • jtatwood Just Startin' 70 posts since
    Mar 18, 2006
    Mar 22, 2011 1:08 PM (in response to jpoprock)
    Keeping it simple with mono is the easiest route but no reason not to try stereo thru the PA. Just use your 2 XLR channels into the board and hard pan RT & LFT. Your FX will sound awesome. I use stereo chorus @ church all the time. The 1/4" output will sum both channels for you so your dual amp tones will work fine, you'll get all info but of course stereo effects will just be mono. Remember to love on your FOH guys. And remember you can loop your guitar and run down there yourself to hear what it sounds like, help EQ it if you need.
    Let us know how it went.
    Peace
    • Stratotron Just Startin' 132 posts since
      Mar 13, 2007
      Mar 22, 2011 1:32 PM (in response to jtatwood)
      From an X3 perspective.
      I found that my stereo delay out of the XLRs was stereo no mater how I panned it. So I patch both XLRs XLR -1/4") out to a DI box and send the sum (Single XLR)  to the board. This has worked really well and no more panning issues ever again.
      The 1/4 inch out is a sum.
      In a pinch, without going in to a lot of detail about the FM study, my blanket rule of thumb is to scoop out the upper mids. And, first time out, maybe try using the rig like an amp with stomp boxes instead of using a bunch of untried patches. In other words, maybe pick an amp model, with reverb and a delay. that will cover the whole set, and punch in and out effects (Distortion/Drive, Modulation) like you were using stomp boxes. Let that be your baseline. Once you get back home, you can design and balance patches to that.
      Just a thought....
        Blessings,
      S
      • darligre Just Startin' 59 posts since
        Jun 3, 2011
        Jun 14, 2011 5:54 PM (in response to Stratotron)
        Very helpful information.  How do you like using your HD500 for church services?  Is there a special Y connector for putting the two XRL's together?
          Mar 13, 2007
          Jun 15, 2011 8:00 AM (in response to darligre)
          There is an XLR  "wye" cable available. I think I described earlier that I made 2 XLR x 1/4" cables and run them to the parallel 1/4" inputs of a DI box and send the  XLR to the board. I love the HD. It is much warmer and "real" sounding than the X3, and I loved my X3! Our sound tech likes it for the same reasons, smoother, less bright than the X3.
          Here are a couple of things. The X3 outputs could be assigned seperately. The HD assigns your output selection to both the 1/4s and the XLRs. After much messing around, here is what I have chosen. I run my HD output assigned to Combo-Front so I have use of  the focus adjustment. However, I run my 1/4" out to the power amp in on my Marshall 50 watt (stage monitor), thus by-passing the pre amp section, and run the summed XLRs to the board. At this point, both the 1/4" and the XLRs have the focus adjustment effecting them. I am running the HD master at about 3:00 or 3/4 volume. The sound tech says the signal level is right.
          I chose this configuration because I wasn't confident in how much my stage amp was tailoring the sound of the HD. Using the power amp in,( actually, effects return) I only have one control on my amp to deal with, master volume up and down ,and it only affects my stage level, which is aimed away from the congregation.
          I was EXTREMELY happy with the results last Sunday. The set really ran the gamut patch-wise. From chimy clean, with a step filter (Seeker) running in the background, to bluesy drive, to a total Brian May harmonized guitar tone a the end of one song. While looking for a synth tone for the end of "You Are Holy" in G. I stumbled across a stock harmonizer patch in the HD called "Puppet Master Solo". It was designed for the key of G and fit it perfectly. I renamed it  "Our Master Solo". For fun, find it on your HD, and play the solo to "More Than A Feeling" by Boston in G and amaze your friends! It also works for the intro to "Ramblin' Man", by the Allman Bros, and "Le Bres" by the Allman Bros, but not in Am. I played it up at 12th fret Em.
          Last Sunday's setlist:
          You are Holy
          Jesus, My Redeemer
          The Jesus Way ( New tune by Brian Doerkson)
          Glorify Thy Name (newer version, not the standard)
          Adoration
          Blessings,
          Strato
              Jun 3, 2011
              Jun 16, 2011 3:59 PM (in response to jpoprock)
              How did you go mono out the XLR out?  Or did you just go out the left 1/4' out to a direct box that switched it over to XLR?
                Mar 18, 2006
                Jun 16, 2011 4:07 PM (in response to darligre)
                Shouldn't need a DI for the balanced out. You can go mono as long as both channels are panned to the same side. Good stuff though.
                  Mar 13, 2007
                  Jun 16, 2011 4:12 PM (in response to jtatwood)
                  I actually built these for my X3L because no matter how I panned the stereo delay, I only got  one side through the XLRs. I use the set up for my HD and it no longer matters how things are panned as I always send a summed mono to the board through the DI.
                  Blessings,
                      Jun 3, 2011
                      Jun 16, 2011 5:00 PM (in response to darligre)
                      I think a few who have replied to some of my questions don't understand what I'm getting at.  I don't want stereo but want to make sure the whole sound is there.  I don't care if it goes back and forth from right to left on a effect.  I just want to have the whole sound and not have silence or something weird when the side not plugged in is missing.
                      Mar 13, 2007
                      Jun 17, 2011 7:54 AM (in response to darligre)
                      Yep! This is the bomb! If I could have walked in to Guitar Center and grabbed one of these off the rack, I wouldn't have built my own. I know I can mail order one and will next time I place a Larger order.
                      And yes again, we are talking about summed mono and not stereo imaging. What I was getting at about my X3 was, I would send only one XLR to the board with everything panned hard to that side and discovered later that only one side of my stereo delay was making it to the board. No matter how I panned it, the timed delay was on one send and the offset delay was on the other. But both sides were coming out of my 1/4", so I was getting a summed mix on stage but it wasn't in the house. For instance on "Stronger" by Hillsongs only the timed delay was being hear in the house, the trailing off triplets weren't. Probably no big,'cept to me!
                      At any rate I figure as long as I use a wye adapter system of some kind, panning to the house is one less thing to think about. Still gotta pan for the 1/4' however...
                      Back in the 90s (pre church club band days) I used a Digitech GSP through a stereo power amp into a split half stack. From where I was standing there was this monsterous stereo imaging, but it was completely lost on the house. Because the house speakers generally were so far apart, that even though I sent 2 feeds to the board they were panned to the center so that one side or the other didn't sound weird. I came to a personal conclusion that stereo imaging is great for recording, but as for live apps, it was really just to make me feel good. That is just my opine...
                      Happy Friday...God IS Good!
                      Blessings, Bro.
                      D
                        Jun 3, 2011
                        Jun 17, 2011 8:50 AM (in response to Stratotron)
                        For anyone out there wanting to buy one of these pedals,  Guitar Center has a $100 off coupon online that you can print out.  The catch is you have to go to one of there stores to buy it because Line 6 equipment is on their exclusion list for buying it online with the discount coupon.
                Mar 13, 2007
                Jun 16, 2011 4:08 PM (in response to darligre)
                I personally built 2 XLR x 1/4" cables about 14" long each. I then use those to patch both XLRs to the parallel 1/4" inputs on a small DI box. Then I send the XLR out of the DI box to the board. I have also seen XLR "wye" adapters from Guitar Center-Musicians Friend ranging from around $25.00- $49.00. I don't recall right now which contacts on the XLRs that I soldered to. The first set of cables that I built were noisy.
                  Mar 13, 2007
                  Jun 23, 2011 9:21 AM (in response to jpoprock)
                  IMHO...The XLRs are panned to however the HD is told to pan them, so any effect you use that has stereo imaging will come out R or L depending. The XLR "Y" cord is by far the simple solution. Make sure it is 2 male x 1 female. The end result is that you will never have to worry about how a patch is panned ever again. It will always output summed mono through the XLR "Y".
                  "*In otherwords, if I happened to have a dual amp config or a ping pong delay, you're not going to hear Amp 1 on the Left and Amp 2 on the Right. Same for the pingpong delay. You won't hear it bounce left and right if standing in the audience.*"
                  My (hopefully simple) comment... Using only 1  XLR send , we will say left borrowing from your example, you will only hear the side that is sent to the board in the house. For instance, if "Ping" is panned R and "Pong" is panned L and you are sending L to the house, standing in the audience you will only hear *Amp 1* and _______ Pong_______Pong _______Pong, etc. Early on with POD devices I encountered the stereo imaging thing with how the choruses and mods were panned. If I sent the effected side or didn't double check the panning, the output could sound weak washy and out of tune.  So, if a patch ever exhibited any of those qualities, the first thing I would look at was panning. In the end for me, it is way easier to send a summed mono.
                  I like the dual amp to mono function through the mixer, because I can still use the mixer volume and pan to 'mix' the 2 amps to mono. It is like having a super active tone control.
                  The other thing I wanted to mention. I took a PDF file of the HD manual on a thumb drive to Kinkos, and for $15.00 got a double side printed-spring bound copy of the manual with plastic cover and the whole thing. Well worth it to me. I don't like trying to study stuff on-line. You could get a 3 hole punched copy for less and stick it in a ring binder.
                  Blessings Bro!
                  strato..
          • pratikb Just Startin' 142 posts since
            Dec 4, 2010
            Oct 11, 2011 5:33 PM (in response to Stratotron)
            Excellent advise..God Bless.
            Pratik
