2973 Views 14 Replies Latest reply: Apr 7, 2011 6:14 AM by bad_ri RSS
bad_ri Just Startin' 9 posts since
Apr 1, 2011
Apr 1, 2011 7:30 AM
Line6 + Rode HS-1
Hello everyone!
I am a sound tech guy From city puppet theatre Rijeka. Lately we were finding a solution for our wireless headsets, as our old Shure LX88 system is beggining to lack in performance.
We were offered to buy Line6 xd-70l system and to expand them with Rode Hs-1 headsets. We also use some old AKG headsets with existing shure transmitters and receivers. Here is the problem: Lavalier mics from Line6 work great with the original system, but I find headworn mics more suitable for some live shows we do. Audiopro sold us the Rode HS-1 headsets along with MICON3 adapters that can hook-up with Line6 transmitters. But the micon adapters kept buring out, because they were fitted with 4,7KOhm resistors. The gain from HS-1 condenser mic is just to high for Line6 transmitter to hande, and I get a lot of distorted signal. The gain knob on my sounddesk is set to min, and the gain is still to high. When I hook up old AKG mics, I get pretty decent sound and no distortion or clipping. Mr Andrew Taylor from Rode Support was kind enough to make me a modified MICON adapters, fitted with 10K resistors (as original Line6 lavaliers have in their 4pin mini xlr), but I still get too much of "gain" from my transmitters/receivers, even with low SPL from actors voices. Still I have to keep my gain knob on the sound desk as low as possible.
Does anybode have an idea what kind of resitor would make this gain from HS-1 headset acceptable for Line 6 XD transmitter to handle without distortion. I say again, my old AKG mics work perfectly with this new system, and I would love this Rode mics to work as well. Help please.
  • dboomer Line 6 Support 1,997 posts since
    Oct 13, 2008
    Apr 1, 2011 1:20 PM (in response to bad_ri)
    Re: Line6 + Rode HS-1
    It's hard to imaging that with the trim control turned all the way down you are getting too strong a signal for your mixer to handle.
    The transmitter input can handle 6V p-p.  The Rode spec says it can only output 189 mV.  When you first lit up the top audio LED you still have 20 dB of headroom.
    You could try omitting the pull-up resistor altogether as the Rode mics do have about 12 dB more gain than our supplied mic.  Or you could use our headset ... which just started shipping a few days ago.
        Oct 13, 2008
        Apr 2, 2011 7:07 AM (in response to bad_ri)
        I'm not sure I understand what problem we are trying to fix.  Do you think the mic is overdriving the transmitter or do yu think the receiver is overdriving the input to the mixer?
        You mention the trim control at 12 o'clock. do you hear distortion if you turn the trim all the way down?
            Oct 13, 2008
            Apr 3, 2011 2:25 PM (in response to bad_ri)
            What am I missing?  The Rode mic only puts out 1/30th of the voltage necessary to clip the transmitter according to its spec.
            Have you tried eliminating the pullup resistor as I suggested?  What happens then?
                • boswell2007 Just Startin' 68 posts since
                  Dec 24, 2007
                  Apr 4, 2011 12:04 PM (in response to bad_ri)
                  The capacitor/ resistor on the Mini PCB in the Line6 TAF4 connector are
                  10K and 10uF
                  HTH
                      Dec 24, 2007
                      Apr 5, 2011 11:26 AM (in response to bad_ri)
                      Maybe the block cap is inside or part of the AKG mic head or the AKG due to its internal config does not require a blocking cap.
                      I use cheap mics and they don't require a cap just a resistor.
  • laplayantonio Guru 2,435 posts since
    Sep 26, 2006
    Apr 7, 2011 4:13 AM (in response to bad_ri)
    RE: Line6 + Rode HS-1
    hello
      I'm afraid we cannot directly help you, as this needs to be tested directly on this third-party hardware
      please contact Rode support, or simply try test using a potentiometer/adjustable resistor to find out the right value
      line6antonio
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
