2210 Views 3 Replies Latest reply: Apr 15, 2011 11:37 AM by Line6Don RSS
briandrankin Just Startin' 3 posts since
Feb 15, 2010
Apr 5, 2011 12:10 AM
Using Podfarm Plug-In in Garageband '11
Hi, I purchased the Toneport/Guitarport Online bundle.
Gear: Intel Mac, version 10.6.7, all Line 6 software is up to date as of 4/5/11
As standalone applications, Podfarm, Gearbox work great but w Garageband...
I followed ALL the steps in this tutorial...
http://line6.com/community/docs/DOC-2071
...for the Podfarm plug-in within Garageband but still get an error message telling me "A required device is either not authorized or not connected..." (see attachment). Everything is plugged in and I'm getting a signal in Garageband but cannot use the plug-in. I've tried reconnecting and restarting, etc. but still get the message. I also tried (within Line 6 Monkey) to REactivate anything I could but there are no options for that. Also tried reinstalling Podfarm, drivers etc, with no luck. Any help would be GREATLY appreciated :-)
Brian
  • Line6Don Line 6 Support 5,274 posts since
    Mar 14, 2011
    Apr 8, 2011 10:05 AM (in response to briandrankin)
    Re: RE: Using Podfarm Plug-In in Garageband '11
    Hey briandrankin,
      I would try using POD Farm in stand alone mode and output the audio into Garageband.
      -With your toneport connected to a USB port on your computer, not a USB hub or extension.
      -Launch POD Farm.
      -Once launched, set up tone that you would like to use.
      -Click on the Mixer tab in center of the program, towards the top, to the right of the Line 6 logo.
      -Using the outputs on the right hand side, make sure to select TONE A for outputs send 1-2.
      -Leave POD Farm open.
      -Launch Garageband.
      -Within the audio options/preferences menu, make sure to select your toneport as the audio device/driver.
      -Create a new audio track in garageband.
      -On the right of garageband, make sure that the input of the track is toneport 1-2.
      From there you should be able to record the sounds you are getting from POD Farm into garageband.
      I hope this helps.
    Mar 14, 2011
    Apr 15, 2011 11:37 AM (in response to briandrankin)
    Hey briandrankin,
      From this point, if you would like to use POD Farm 2 as a plugin in Garageband, you will need to purchase a license. They are available on our online store:
      http://line6.com/store/
      On the main page, you will see POD Farm 2 plugin, make sure and select your device from the pull down menu so that you purchase the correct license.
      If you have any further issues, just let us know.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
