Apr 18, 2011 7:41 AM
Quest about Pod Farm 2 and Guitarport
Like (0)
Hello! : )
I am using Guitarport with additional expansion packs. Now i would like to use dual tones, and since it needs double work when using only guitarport, i would like to use pod farm 2 as a plug in for my DAW.
a) Can I add these expansion packs i already bought to pod farm 2? because as i`ve seen, they are not standard in PF2.
b) Can I load my Gearbox tones to PF2?
c) Am I right if i say, there is no difference in sound but only Pod Farm is a plug in and Gearbox is not?
cheers and thanks!
- syn
you will still have all your model packs available if you upgrade to pod farm 2...
tone is the same as gearbox...
and yes,.... you can use the same tone files.
and you will get the plugin when you upgrade.
