2499 Views 1 Reply Latest reply: Apr 29, 2009 11:59 AM by Kneehow RSS
robbygupta Just Startin' 2 posts since
Mar 8, 2009
Apr 26, 2009 3:42 PM
My TCDDK does not power up
Hello,
I just got my TCDDK. I installed the software and was ready to power up.
I installed a (brand new) 9V battery, connected the USB cable to the pedal and to the computer, connected the 1/4" cable to the input jack (Mono/L), and nothing happened. I pushed on the pedal and still nothing. I tried another brand new battery and got the same result. I then verified that the first battery works by installing it into an old Boss Distortion pedal. The Boss operated fine.
Looks like it is a power up issue.
Please tell me how to proceed.
By the way, I'm not even sure if this is the right place to go for help. If not, please tell me where to go. The website had me going in circles.
Thanks,
Robby Gupta
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Apr 29, 2009 11:59 AM (in response to robbygupta)
    Re: My TCDDK does not power up
    First, while it is possible to use battery power with the TCDDK's, I highly recommend that you use a power supply for a constant power source.
    In case you choose to not go with the Line 6 DC-1 power supply, the proper specs would be: 9.6 VDC, 200mA current and center pin MUST be negative.
    Please try powering up with a power supply just for troubleshooting's sake. Another thing to do is to remove the 2 hex screws which secure the top module plate. Push in on the circular plastic release mechanism and use a dry cloth to wipe the connection points on the bottom of the module. You should do the same on the dock surface. Re-seat the module and reinstall the hex bolts.
    If your unit doesn't even power up, you should give us a call at: 818-575-3600 (8AM-5PM Pacific Standard Time, Monday-Fridays). Select the Service Department queue and we can help you out.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
