697 Views 6 Replies Latest reply: Nov 10, 2012 6:13 PM by toneman2121 RSS
fmetting Just Startin' 3 posts since
May 27, 2007
May 15, 2011 3:50 PM
PODxt displays "Invalid Error Code 02" when turned on.
My PODxt is displaying "Invalid Error Code 02" on the screen when I turn it on.  The last time I did any sort of update was about three years ago, when I installed FX junkie.  I no longer use the computer that I did the Line6Money update with.  Is there any way to fix this error?  If it can be fixed, will I lose my FX junkie install?
Thanks,
Frank
  • Triryche Expert Line 6 User 3,698 posts since
    Feb 20, 2007
    Try to reflash the PODxt.
    No, you will not loss your FX Junkie, it is tied to your account and the license resides in your PODxt.
    Reflash Doc:
    http://line6.com/community/docs/DOC-3827
        • jonzie55 Just Startin' 1 posts since
          Dec 19, 2009
          my computer doesnt have a midi input. do i use a midi to usb converter? or is that the same as just using the usb?
          • toneman2121 Gear Head 1,985 posts since
            Oct 15, 2006
            Q: My unit cannot update via USB, and I have Flash Memory 1.0x.  How do I update from Flash Memory 1.0x to a newer version? A: First verify you have flash memory 1.0x. Please hit the TUNER button and scroll using the SELECT knob to the last page. If you have a version later than 1.0x, you can use your USB connection. In order to update your PodXt from version 1.0x to the latest version, you will need to download Line 6 monkey (as described above) as well as a MIDI to USB interface. We recommend the MIDI SPORT UNO from M-AUDIO.  Install the drivers for your interface, then run LINE 6 MONKEY with your POD XT unit connected to your interface. Click on the CONNECT USING MIDI CABLES button, and make sure that you see the MIDI IN and MIDI OUTS set to your interface. Then go through the FLASH MEMORY installation as described above. After this is done, you will be able to update your PODxt series unit using USB.  See the following link for more information on connecting to your Line 6 unit via Midi: http://line6.com/community/docs/DOC-4287
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
