909 Views 10 Replies Latest reply: Aug 2, 2012 11:09 AM by DickFoster RSS
HJAO Just Startin' 11 posts since
Jan 28, 2007
May 21, 2011 3:57 PM
Vetta II Combo, turning volumeknob or volume on pedal reacts sluggish/slow
Hai All,
I have a problem on my Vetta: if I turn the volume, it reacts slowly. It looks like it reacts in "steps". Also the "Edit" button many times does not react at all so I can't edit any presets. Also my Variax can not be detected through the Vetta anymore? Anybody else had these problems? Should I do a factory reset or is there something really wrong/broken?
Best regards,
Henk-Jan
        • jvblack Iknowathingortwo 190 posts since
          Oct 20, 2007
          A couple of ideas:
          Have you checked the internal ribbon cables?  Maybe something is loose.
          See my comments here:
          http://line6.com/support/thread/61629?tstart=0
          Is your vetta getting clean power from the outlet?  Vetta amps are very sensitive to voltage fluctuations.  See my post here regarding glitches:
          http://line6.com/support/thread/71102?tstart=0
          Let us know what happens, please.
          Good luck,
          Joe
              Oct 20, 2007
              I don't know about fluctuations affecting the vetta when it's off.  I will tell you that since i had the discussion about this with the technician, i have never plugged my Vetta into anything but the regulator.  Since then, i have not had to reinstall the software, which i did have to do a couple of times prior to that due to the "patch switching delay" (if you're not familiar with this,it is a known problem:   if it takes 2 to 5 seconds to switch from one patch to another, this is an indication that your software is corrupted, and it is resolved by re-installing the software.).
              I hope your problems are easily corrected.
              Good luck,
              Joe
