1898 Views 9 Replies Latest reply: Jun 7, 2011 4:40 PM by geebake RSS
Hellharicot Just Startin' 25 posts since
Aug 23, 2010
May 25, 2011 4:59 AM
Pod GX + Pod Farm 2.5 : Only Dry sound
Hey Line 6,
Firstly I'd like to thank you because you really helped me with my previous issue, and I finally got my Pod GX work on my laptop!
But there have been some uptades and now I have Pod Farm 2.5! I installed it, I installed my drivers, I authorized it, and, really happy, I turned it on... Okay well, I can't deny it : the unplugged and dry sound is amazing, but how do I get the processed sound? My settings in Pod Farm 2.5 are correct. I tried using it both in Standalone and in VST in Sonar, I only have the unprocessed clean sound. But it works fine with Amplitube! So I assume my GX works fine, such as my DAW. (the problem is that I don't wanna use Amplitube, Podfarm is much better ><)
Then, how can I set my GX at 24 bits? Seems not working. By the way, the ToneDirect Buffer, on this computer (PC, Win7 64bits, 8GB RAM) can't be set at Extra small... When I set it at 24 bits, and apply it, I get a white annoying noise, and when I set my buffer at Extra Small, I get no more sound... Quite weird but also pretty annoying! ^^'
As I said above: this is a good PC, so I don't think the problem comes from the performances. It seems not to be my GX, you already tested it and it works fine with amplitube.
May I please have your help? (I already tried uninstalling everything, doesn't work either)
Cheers!
  • Line6Don Line 6 Support 5,274 posts since
    Mar 14, 2011
    May 27, 2011 11:33 AM (in response to Hellharicot)
    Re: RE: Pod GX + Pod Farm 2.5 : Only Dry sound
    Hey Hellharicot,
      Please make sure to check the Record Output within POD Farm's mixer tab to configure your outputs. You will need to configure them for wither TONE A or TONE B instead of the dry tone. Please reference the screen shot below:
    As far as the buffer size issue, try using the setting just to the right of the extra small buffer size. You will just to try different combinations of settings to see what works for you on your system.
    Jan 27, 2010
    Jun 3, 2011 5:00 PM (in response to Hellharicot)
      This issue could be related to a USB filter driver installed on your system.
      Try looking over the info in this DOC and see if it helps.
      http://line6.com/community/docs/DOC-2215
      Also, BSOD's are often related to conflicts with video cards. Try updating the video card in your computer to the latest drivers supplied by your manufacturer.
      Thanks,
      David
      Line 6 Customer Support
    Mar 14, 2011
    Jun 7, 2011 4:21 PM (in response to Hellharicot)
    Hey Hellharicot,
      You should be able to control the bit rate and sampling rate from the Line 6 Audio-MIDI device menu. If you are making changes to this and they are not staying, there is either a difference with the operating system audio preferences setting, or you are using a recording application that has taken control of the driver settings. At which point you will need to make the changes to the preferences within the application.
      In terms of you only hearing the dry sound, that is an issue we are currently looking into.
      Please review the following link for more information and workarounds:
      http://line6.com/community/docs/DOC-2304
  • geebake Just Startin' 63 posts since
    Mar 12, 2007
    Jun 7, 2011 4:40 PM (in response to Hellharicot)
    Re: Pod GX + Pod Farm 2.5 : Only Dry sound
    I have the exact same problem. Nothing but the dry signal coming out from POD Farm 2.5 wether in stand alone or as a plug in. I'm using an original UX1 and am positive that the outs are setup correctly.
    Sure hope you guys have a sollution soon. It's obviously quite frustrating.
    Greg
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
