1117 Views 7 Replies Latest reply: May 26, 2011 12:41 PM by elroloh RSS
elroloh Just Startin' 8 posts since
May 8, 2011
May 26, 2011 11:18 AM
Disabled Amps
Hi, first of all I'd like to thank line6 for this board, awesome work fellas
now, I've got a question about default presets, or factory presets, whatever you wanna call them, i've got at least 20 with disabled amps that won't work on any one I select, it say's it's because of the DSP usage, all right, got that when I read the manual
ain't a way to "fix" this somehow? i'm just stuck with a coulpe dozen of presets without amps? this happens the most on the heavily effected list
also on this same list, the last bank and other presets in the middle just won't work at all, no sound anywhere, it's not that they just don't have an amp (which I don't mind if it sounds nice), but I can't hear anything at all, what's wrong in there? am I doing something wrong or what? I've tried a couple of things to make them sound, but with no luck at all
I think that's it (for now at least ), so, thanks again for my new toy
    Dec 22, 2006
    May 26, 2011 11:32 AM (in response to elroloh)
    Re: Disabled Amps
    the ones that just don't work... you might check the inputs... they could be setup for mic...
    have you updated to the latest firmware? and the latest driver/edit version?
  • johnnyayyy Iknowathingortwo 1,170 posts since
    Feb 24, 2010
    May 26, 2011 11:36 AM (in response to elroloh)
    Re: Disabled Amps
    I am guessing you are running firmware 1.31? There seems to be a problem with 1.31, for some reason the DSP usage is higher and patches that work in the earlier versions of the firmware will not open properly in the latest version and you will get the DSP error message.
    Hmmmmm... This is the first time I have heard of the factory presets not working... you might want to try reinstalling the firmware and when you come to the part where Monkey asks if you want to keep your presets say no - the factory presets will be reinstalled. Be sure to save any presets you have already made to your computer and you can put them back on the Pod after the firmware reinstall.
    If after all this you still can't use the factory presets you might try rolling back the firmware to an earlier version, figuring out which presets you like, and maybe tweaking them for lower DSP usage (maybe deleting an effect you don't need or trying a different reverb as some reverbs use more DSP than others) and resaving them to your computer reinstall after you go back to the 1.31 firmware.
    • silverhead Expert Line 6 User 9,592 posts since
      Apr 1, 2009
      May 26, 2011 12:15 PM (in response to elroloh)
      Re: Disabled Amps
      elroloh wrote:
      .... but is there a way to globally control what input i want to use with my pod? ..
      No. The selection of Inputs is a per-preset setting. It is saved with the preset when you save the preset. If you switch presets without saving, the change will be lost.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
