15389 Views 36 Replies Latest reply: Oct 6, 2011 4:20 PM by drdamski RSS
thorneven Just Startin' 139 posts since
Jan 29, 2009
Apr 28, 2009 8:00 PM
To Line6 - diagnosis for "access error" ?
Hi All at Line6.  I want to get my Vetta I Combo fixed, but before I drive 60 miles to the nearest repair center and spend $150, and since this problem is intermittent (which means the repair center will not likely be able to reproduce it), I'd like to know if anyone at Line6 knows what the problem is when the error on the display reads "access error".  I'd appreciate a response, definitive if possible, from Line6.  If the repair center cannot duplicate the problem, they're going to ask Line6 this question anyway.  Thanks so much.  thorne
UPDATE - I left my amp on for about 6 hours, plugged in an FBV Shortboard and proceeded to change presets from the pedal continuously and rapidly.  I was able to reproduce the "access error" three times.  I'm guessing that overheating may have something to do with it.  I hope this helps you help me diagnose the problem.  As a programmer for 30 years, when I get a specific error message, what I do is go search all the code for occurances of that error and see under what conditions that error occurs.  Line6, if you could do that for me, I think it would be a great help.  Thanks.
  • Line6Andy Line 6 4,345 posts since
    Jun 5, 2006
    Apr 29, 2009 9:23 AM (in response to thorneven)
    Re: To Line6 - diagnosis for "access error" ?
    Hello,
      Your unit needs to go to a service center.  Please see the following links:
    Vettta Trouble Shooting F.A.Q.s
    http://line6.com/community/docs/DOC-3842
    Product Repair
    http://line6.com/community/docs/DOC-4285
  • jvblack Iknowathingortwo 189 posts since
    Oct 20, 2007
    Apr 29, 2009 10:20 AM (in response to thorneven)
    Hey Thorn,
    Just a note to say I'm sad to hear that your having vetta problems again, and that i hope you finally find some solution.
    It looks to me that (like me) hardly anybody looks at these forums much anymore, including the Line6 guys, who are just copying and pasting the same stuff again and again as their "advice" or "solution".
    How things have changed....
    Good luck!!!!
    Joe
    Oct 20, 2007
    Apr 29, 2009 10:24 AM (in response to thorneven)
    I may have forgotten your answer to this from previous discussions of your vetta issue:
    Does it do the same thing when you change presets from the amp, or only with the foot controller?
    Did you plug the foot controller into the amp AFTER you let it run for six hours?  I've never tried plugging the foot controller in (i use the FBV) while the amp is on; i always power the amp up with it plugged in.  Could that be related?
    Just thinking out loud...
    Joe
    Jun 5, 2006
    Apr 29, 2009 3:16 PM (in response to thorneven)
    Hello,
      There is no "single" cause for this error, so the service center is going to need to go through the unit to diagnose and repair the problem.
  • ricksox UberGuru 11,641 posts since
    Mar 28, 2006
    May 4, 2009 3:38 PM (in response to thorneven)
    The problem with that error is that it could be an number of things that are causing that error. It's sort of like a "Check Engine" light situation. Taking it to a service center is the best move in this case.
    Line6Miller
    • drdamski Just Startin' 15 posts since
      Dec 12, 2009
      Oct 6, 2011 4:20 PM (in response to ricksox)
      I realise I'm dragging up quite an old thread but I was pleased and concerned to find that when I googled the term access error - this thread showed up.
      I was pleased because I hoped I'd find a solution given that others had experienced the issue.
      I was concerned because it quickly became apparent the pain this was causing users who experienced it.
      I love my vetta (1st gen Head with 2.5 upgrade) but it started crashing on me at a gig, and I was lucky I got through the gig with it because when I got it home it got worse and became unusable - I couldn't trust it to gig with.
      I took it to my local dealer - Mr Music in Taplow, UK - who were extremely helpful, and sent the Vetta away to Line 6 for repair. It's back now having been apparently tested for 3 days solid, and having some soldering done. £70 including postage which I thought was very reasonable given what I was fearing having read the above costs...
      Within two hours of noodling around at home I've recreated the error already.
      Gutted.
      Was thinking of upgrading to POD HD + DT series, and having Vetta as back up, but I wouldn't even use it for that now... might have to ditch it and buy a couple of spiders instead as I can't afford DT + POD + a spare.
      I'm also not keen to pay for £100's more to get the vetta repaired if I could just buy something else...
      hmph...
    Mar 28, 2006
    May 21, 2009 4:04 PM (in response to thorneven)
    It could be that your preset bundle had a corrupted patch somewhere. Do you have a copy of the bundle you were using that you can attach to this thread. I'd be happy to load it up on our Vettas here.
    Line6Miller
    Jun 5, 2006
    May 22, 2009 3:59 PM (in response to thorneven)
    Hello,
      I installed the bundle you provided to a Vetta II and played around with it for a couple hours.  I was not able to reproduce an "access error", so it sounds like there is a hardware problem that the service center will need to diagnose and repair.
      • candreasffm Just Startin' 78 posts since
        May 20, 2006
        May 23, 2009 8:10 AM (in response to thorneven)
        You could try the "Vetta-Check" found in the german Line6 Forum:
        http://www.line6forum.com/phpBB2/kb.php?mode=article&k=31
        Original: http://www.soundside.de/_modifications/Vetta-Check.htm
            Oct 20, 2007
            May 29, 2009 9:39 AM (in response to thorneven)
            OUCH @ the price.  There was (two or three weeks ago) a Vetta II head, 4x12 vetta cab, and FBV longboard here on craigslist that looked like new for $1500 (the guy also had it on ebay at the same time with a $1000 reserve and mentioned in the craigslist ad that he might take less).  I thought of sending you the link, but it's a long way from South Texas to where you are.
            I hope they finally get it working the right way for you.
            Joe
        Jun 5, 2006
        May 26, 2009 11:03 AM (in response to thorneven)
        Yes, I followed the original recipe you provided and I was not able to reproduce your situation on a Vetta with your presets.  It sounds like you have an internal hardware error that the service center will need to diagnose and repair.
  • Bubblecum Just Startin' 1 posts since
    Jun 5, 2009
    Jun 5, 2009 12:55 PM (in response to thorneven)
    Thought I'd hijack this thread instead of creating a new one.
    I just purchased the Vetta II head here in sweden where I live, paying the nifty sum of aproximatly 2500$.
    I use it for i couple of hours over the next few days, and now I cant even get the head to start. On startup the display just says "Access error".
    Is my only option to return my amp? Cus I dont think we have any service centres around here.
      Oct 20, 2007
      Jul 14, 2009 8:51 AM (in response to thorneven)
      I think Thorne had done all he can do.
      Line 6:  It's time to take some responsibility for this unit and the performance of the "authorized" repair center.
      Just my opinions,
      Joe
          Oct 20, 2007
          Jul 14, 2009 9:46 AM (in response to thorneven)
          Perhaps I spoke out of turn.  I hope it works out for you and doesn't wind up costing you a bunch more money.
          The vetta is such a cool solution to most gig requirements.  I can't imagine trying to put together some kind of amp/pedalboard rig that does everything that can be done with the vetta and FBV.   I hate to see one go bad.
          Hang in there,
          Joe
    • Stevem57 Just Startin' 1 posts since
      Jun 17, 2007
      Jul 31, 2010 7:51 AM (in response to thorneven)
      Oh my Lord! Sorry to hear your troubles, but it’s nice to know I am not alone. I have tons of Line6 gear. Being a technologist like yourself, I was initially so swept away by the technology I went hole hog thinking it would be a perfect marriage, key word here being MARRAGE. Legacy technology affords you the freedom to do your own repair work, with line6 your reliant upon them for everything, and your subject their rules and regulations.
      I bought my Vetta I back in 1998 I believe, They sold me the unit and the Edit software was not available for at least a year I had been getting the Access error right along, but it was always intermittent, the unit usually recovered after letting it cool down. Then the power stage went, I asked line6 if they would sell me the parts to replace as the unit was no longer under warranty, of course that would undermine their authorized repair centers, so they offered to fix it for me which I thought was nice, the price was also discounted.
      Within the past year or so the Access Error has been more persistent, it was not going away so easy, yesterday morning I practiced a bit before going to work and left the amp on, I was a fairly hot summer day, no AC on when I am not home, so it got hotter than usual I suppose and bam! Now I have a permanent Access error, had the amp unplugged since last night turned it on this morning and no good! The repair center near me wants $75 just to look at it, but it goes toward the cost of the repair, I suspect the board is also around $400.  I really do not have the money to lay out right now, I guess I will have play with Guitar port for a while on My PC. Sounds like a wimpy transistor radio
    Jun 5, 2006
    Jul 14, 2009 9:57 AM (in response to thorneven)
    Thorn,
      Sorry to hear that you are continuing to have problems.  The repair carries a 90 day warranty, please return the unit to the service center to have them take care of this situation.  Let us know if you need further assistance with the service center and we can get involved if necessary.
    Jun 5, 2006
    Jul 14, 2009 11:32 AM (in response to thorneven)
    Hello,
    Please see your support ticket for more information:
    What is a Support Ticket?
    http://line6.com/community/docs/DOC-1422
    Q: What is a support ticket?
    A: A support ticket allows you to directly correspond with a Line 6 Support Representative. An email will be sent to you from Line 6 containing a link if a Line 6 support representative determines that a ticket is necessary to troubleshoot your issue. Please follow the link in the email to view your open ticket to work one on one with Line 6 Support.
    Please note: Sometimes support tickets will be filtered to spam and junk folders. If you did not receive an email from us indicating that a ticket has been created, please make sure to check those folders in your email host.
    http://line6.com/account/tickets/view/
    • DFlynn666 Just Startin' 73 posts since
      Apr 19, 2008
      Jul 12, 2010 9:44 AM (in response to Line6Andy)
      appologies for hijacking the thread, but i am having similar problems with line 6 repairs, I sent my amp away while it was under warrenty, and an the original post says, its an intermittant problem. I have a spider III HD150 and when i turn it on, (having a shortboard attatched) the volume turns itself up and down, the screen doesnt light up and changing presets has a delay of around 2 - 5 seconds, if it changes at all.
      I had the amp sent while on warrenty, and they said there was nothing wrong with it, but they replaced a few diodes or something to make sure. Now the exact same problem is happening again, except, I do not have alot of money for to pay for repairs as its out of warrenty, and i want to be sure it WILL be repaird because i cannot afford to keep sending it away after they say there is nothing wrong with it although there blatently is.
      Also I have created a thread and Line 6 do not seem to want to answer my enquiries about service centres after warrenty has ran out.
      I need major help - someone please
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
