1841 Views 7 Replies Latest reply: Jun 17, 2011 1:38 PM by Line6Don RSS
chrisusher Just Startin' 5 posts since
Jun 25, 2009
Jun 5, 2011 12:39 PM
POD X3 Live with EX-1 Tweak Settings Query
I've just bought a POD X3 Live having just upgraded from POD XT Live which I also use a EX-1 to boost drive/gain when necessary.  I love both the POD XT which has served me for many years and am loving the POD X3 Live already.
On the POD XT Live when I used the EX-1 the drive/gain could go all the way to 100%.
When I use it with the POD X3 Live the EX-1 max value can only be the value set on that particular effect when dialing in the preset.
Is there a way to rectify this??
I really don't want to set all my stomp effects higher and just adjust them downwards with the EX-1 all the time.  I just want to have the EX-1 set at half and then push to the toe position for more gain/drive above and beyond the value set in the preset.
Or is there a way to set min and max values for tweak settings?
Thanks.
Chris
  • Line6Don Line 6 Support 5,274 posts since
    Mar 14, 2011
    Jun 10, 2011 2:05 PM (in response to chrisusher)
    Re: RE: POD X3 Live with EX-1 Tweak Settings Query
    Hey chrisusher,
      Unfortunately the POD X3 Live operates and utilizes the secondary expression pedal differently than XT Live series did. Please reference the excerpt from the POD X3 Live Advanced Users Guide below for all the information on setting up the secondary expression pedal for different parameters.
      Here is a link to the POD X3 Live Advanced User guide:
      http://l6c.scdn.line6.net/data/l/0a060072a53c4aae7fe287ecf/application/pdf/POD%20X3%20Advanced%20Guide%20(Rev%20E)%20-%20English.pdf
      • silverhead Expert Line 6 User 9,592 posts since
        Apr 1, 2009
        Jun 11, 2011 6:41 AM (in response to chrisusher)
        chrisusher wrote:
        Can you please let me know how the EX-1 is now handled in the POD X3 Live and possibly how I can manage it so that I can push the tweak pedal so that the pedal pushes gain and drive past the value set in Gearbox, without changing all my presets?...
        In the X3 Live the EX-1 would be Pedal 2 in the manual description. You can assign Pedal 2 to TWEAK any one of the parameters that appear in the corresponding list when you assign the pedal. This is a per-preset setting; there is no global setting that will allow you to do this without changing all presets.
    Mar 14, 2011
    Jun 13, 2011 10:46 AM (in response to chrisusher)
    Hey chrisusher,
      Just as SilverHead mentioned, "This is a per-preset setting; there is no global setting that will allow you to do this without changing all presets."
      The POD X3 and the POD XT utilize the EX-1 differently, so you will not be able to use the EX-1 in the same manner that you used it with the POD XT.
      You will need to program the tweaks function for every preset that you desire to use the EX-1 with.
    Mar 14, 2011
    Jun 17, 2011 1:38 PM (in response to chrisusher)
    Hey chrisusher,
      Unfortunately there are not any more tips that I can provide concerning the use of the EX-1 and the POD X3 Live.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
