Jun 9, 2011 10:01 PM
M13 smart harmony
Like (0)
hi..is there anyway to disable the Scale and the key in the m13...just make it linear?
most of my solos doesnt fit the scales available at the effect but i really like the sound of it when its on key.
If you want absolute pitch shifting, use the Pitch Glide effect. That should do what you want to accomplish.
this is not what im looking for.
what im asking is if there is anyway i could harmonize the part im playing without using the "Scale" option.
example: if im playing a lead part and i want to harmonize it by adding a 1.5 steps up to the original part im playing.
thanks in advance.
The Pitch Glide effect will let you do that. It can be used for static, absolute pitch shifting. It doesn't have to be used as a Whammy type effect. Just set the pitch to wherever you want it, set the mix and you'll be good to go. It will harmonize everynote you play to the same interval. There's no way to disable the scale on the Smart Harmony.
