Jun 11, 2011 8:18 AM
How can I get four simultaneous effects on POD HD300?
Like (0)
I just can use three of them on the amp simulation mode selected (red light on mode button). When on amp simulation mode, if a press the first footswitch (Amp / bank A), it turns on the amp simulation, even if I have the button FX Only hitted...
So, how can I use the 4 simultaneous effects announced, with no amp simulation. I basically need just that, for start playing. Amp simulation is an improvment for later!!
Thanks for any help.
I guess I don't understand the question.
You only have 3 simultaneous effects on the HD300, plus the reverb.
The footswitches down the bottom (FS2-FS4) allow you to individually enable/disable each of these 3 effects. FS1 is to turn the Amp simulation on/off. These footswitches can also be used to select stored presets when not in stompbox mode.
Can you rephrase your question differently as I'm a little confused by what you are asking?
Greetings!!
Hey ozbadman, you have already answered my question, even not understanding it!!! hehehe
The point is that I didn't find anything as clear as you described, about having 3 simultaneous effects PLUS THE REVERB!! I thought I could have four M-class FX simultaneously.
That plus wasn't explicit for me..., with your comment I noticed perfectly.
Believe me, you helped a lot.
Thank you.
Ahh. Excellent. Glad you've sorted it out.
