2787 Views 9 Replies Latest reply: Sep 23, 2011 6:45 AM by sgenevay RSS
nazgul_927 Just Startin' 3 posts since
Dec 3, 2010
Jun 24, 2011 1:37 AM
POD Farm 2 won't play amp/pedal tones
Hi, recently i've been having problems with my UX2 Pod using POD Farm 2 version 2.51. Everything loads up fine: I can select what amp I want; whatever pedals I want etc, but when I play the guitar I get no effects or amp gain at all. It's as if the input level has bypassed the effects and gone straight to the output, giving me a really weak and bland signal.
This was happening in version 2.02 of POD Farm 2 initially, so i've tried updating it to version 2.51, i've re-installed the drivers numerous times. I don't know what else to do.
Thanks.
    Jan 27, 2010
    Jun 24, 2011 3:36 PM (in response to nazgul_927)
    RE: POD Farm 2 won't play amp/pedal tones
      This is an issue I have not heard of before. Do you see the input meters light up?
      Have you tried different cables and guitars?
      Are you connected with a USB hub?
      Thanks,
      David
      Line 6 Customer Support
      • Kelvis360 Just Startin' 98 posts since
        Aug 27, 2010
        Jun 25, 2011 2:25 AM (in response to nazgul_927)
        Re: RE: POD Farm 2 won't play amp/pedal tones
        lol .   Yup, same thing happening to me too.   And a few others - David, you should check pages 9 & 10 of this thread:
        http://line6.com/community/thread/63722?start=120&tstart=0
        Should I post a new question referencing PF2.51 for this to be addressed for me too?
        Edit:  PS, I'm on Win7 32-bit and rolling back to 2.02 *does not work* for me, even after uninstalling, manually removing the folders in users\appdata\roaming\Line6 and the Line6 folder in the hidden 'program data' folder, removing the relevant registry entries, rebooting and then reinstalling.
        Still exhibits the same problem as 2.50 and now, 2.51.   NO PROCESSED SOUND.
        The input meters light up.   I've tried different cables and guitars.   I'm not connected to a USB hub.  I'm quite sure it's a Line 6 problem, not a cable, guitar or hub problem.
        Please help.
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    Jul 6, 2011 9:29 AM (in response to nazgul_927)
    nazgul,
      You mentioned that you are connected into a hub.  Please completely disconnect the USB hub from the computer, even if it is not in use.  Also, please remove all other USB devices from the computer (except for a mouse/keyboard and the UX2), and test the UX2 on all of the computer's USB ports.
      Let us know if the problem persists.
      Regards,
      Line6Hugo
    • EvolutionVII Just Startin' 1 posts since
      Apr 20, 43486
      Jul 8, 2011 5:33 AM (in response to Line6Hugo)
      This is no hardware error.
      I'm also having this issue using Reaper x86 on a Win7 x64 computer.
      The minute I open/close my DAW the amp models are bypassed. There's still some sound processing going on (delay etc. still works).
      If I'm using the Cali Diamond Plate by default, I have to switch to the Treadplate model, back to the Cali Diamond Plate and play around with one of the knobs. After this it's working "perfectly" fine.
      This only works for one instance of the VST, if I add another instrument I have to go through all of this again.
      The problem with this is, that you cannot save your settings, you'll have to remember them yourself.
        Apr 8, 2007
        Jul 11, 2011 11:02 AM (in response to EvolutionVII)
        As similar as your problem seems, it can never be assumed that you are having the same issue.  USB hubs are NEVER supported as they can cause connection issues that will affect what is authorized to work and what isn't.
        I do suggestion creating your own support thread to discuss the problems that you specifically are having:
        http://line6.com/community/community/support/
        Just click on Ask a Question to begin creating your thread.  Please make sure to fill out your support profile, provide as much detail on the problem and what  you have tried, and a detailed recipe of how to reproduce the problem.  Software versions should be noted to let us know what versions of  your software you are using.
        Regards,
        Line6Hugo
  • Line6Don Line 6 Support 5,275 posts since
    Mar 14, 2011
    Jul 18, 2011 10:25 AM (in response to nazgul_927)
    Hey nazgul_927,
      Glad to see that you were able to get it back up and running. Thank you for posting your results as well.
  • sgenevay Just Startin' 1 posts since
    Jun 12, 2008
    Sep 23, 2011 6:45 AM (in response to nazgul_927)
    Re: POD Farm 2 won't play amp/pedal tones
    Hey ... did u find a CORRECT issue to your problem ? i mean did u find a logical explanation or did it just go fine by itself ? cause i have exactly the same problem. on Mac in Protools 9...   My firewire sound card is plugged right into the mac.... and podfarm is acting as if it was bypassed... i heard my guitar sound unprocessed.... I have check and check everything again but this is weird... even all saturations sound weird when i finally get some sound on several preset....
    Any Idea ?
    Thx.
    Sylvain
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
