1927 Views 8 Replies Latest reply: Sep 13, 2011 6:36 PM by chiec RSS
chiec Just Startin' 12 posts since
Aug 12, 2006
Jun 27, 2011 11:36 AM
PodX3 bean stops working (seems like a USB dropout)
I use the PodX3 as a soundcard, and sometimes it stops working and he decide he won't untill I restart it. I can't record anyting because it only last like 2 minuts working, is very frustrating.
I use Windows7 and the last PodX3 driver. Help please.
    Jan 27, 2010
    Jun 28, 2011 12:03 PM (in response to chiec)
    RE: PodX3 bean stops working (seems like a USB dropout)
      This issue could be related to a number of things. First check your connections.
      Have you tried connecting to different USB Ports?
      Are you using a USB hub?
      Then try the optimizations in our USB Troubleshooting Guide:
      http://line6.com/community/docs/DOC-4282
      Thanks,
      David
      Line 6 Customer Support
    Jan 27, 2010
    Jun 30, 2011 4:35 PM (in response to chiec)
      Reaper should function correctly. A lot of our users use Reaper without issue.
      Have you installed the latest drivers for the interface?
      http://line6.com/software/
      Thanks,
      David
      • fHumble_fHingaz Just Startin' 5 posts since
        Sep 7, 2008
        Jun 30, 2011 11:18 PM (in response to chiec)
        Re: RE: PodX3 bean stops working (seems like a USB dropout)
        I am having this exact same problem.  I have been using my Pod X3 for some years now to record my basses & guitars direct into Sonar 8.5PE using Windows XP home on an Intel Core 2 Duo @ 2.66GHZ with 3.24GHz of RAM... It has run completely trouble-free, up until a few weeks ago.  Now, when I try to record using the Pod, it runs for about 2 minutes, then playback from my DAW stops.  The files keep playing, but no sound is reproduced. Sonar does not register a "dropout".  My CPU usage is minimal.  If I only shut down Sonar (& the Pod) & open it again, Sonar doesn't "see" the inputs from the Pod.  I have to restart my computer before I can get the Pod to start acting as the audio interface again. I too, have experimented by swapping USB cables & ports.  I am not running it on a USB hub.  I have updated to the latest drivers, but nothing has changed.  Sonar runs problem-free with my other interface (M-Audio ProjectMix IO) After such a long time of problem free recording, this is extremely frustrating...Please help.
Bookmarked By (1)
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
