323 Views 0 Replies Latest reply: Jun 29, 2011 1:56 PM by mdme_sadie RSS
mdme_sadie Just Startin' 113 posts since
Sep 18, 2009
HD500 Edit Amp List frustrations
Is anyone else bothered by the amp list dropdown?  It just seems a little clunky, it always scrolls all the way down so that you have whatever amp selected as the top one on the list,which is actually really annoying as most of the time that means you're looking at pre's first, which is almost never my first choice for amps.  Scrollwheel doesn't work well in there either.  It's a massive list with even the small selection of amps available in the HD currently.
Wouldn't it be nicer if it was organized into categories.  Like High, Mid and Low Gain.  Then maybe even under that grouped by amp if there are multiple channels.
Finally how about ditching the "Pre's" and making it so that the full amp with master section dialed back to 0 (which gives you the same sound as just the pre) would result in you just having the pre, thus also reducing DSP when that happened.
There's a lot of cool stuff on this unit and it just needs a little organization and cleanup.  Otherwise once we start getting model packs it's going to be unusable.
