1688 Views 8 Replies Latest reply: Jul 22, 2011 4:25 PM by Line6Hugo RSS
sketterman Just Startin' 6 posts since
Oct 16, 2010
Jul 17, 2011 4:29 PM
Cannot Updated Flash Memory on POD XT
Hello,
I only recently found out about Line 6 Edit, and am now in the process of using it. I have downloaded and installed Monkey, as well as L6 Edit. I created this account, and registered my POD XT.
** I have included a screen capture to help with these issues ***
When I opened up Monkey, I went ahead and downloaded the drivers, and then I updated the USB firmware. Now, when I try to update the Flash Memory, I do not have the ability to update it. When I highlight the Flash Memory option in Monkey, the "Update Selection" box is greyed out, and there is a ? to the left of "Flash Memory".
Also, when I run Line6 Edit, I only get a "Midi Devices" dialogue box, which shows my PODxt along with a giant yellow ?. If I click "OK", this box disappears and immediately re-appears. Clicking the "add" button only gives me the option to add a MIDI device (I am using USB), and clicking refresh will bring up the same thing.
I tried powering down my machine, reinstalling the software, and various different "startup procedures" (ie, turn on the POD first, then open Line6 edit / Open Line 6 edit first, then turn on the POD) and nothing seems to work.
The image is attached. Any assistance would be greatly appreciated, and thanks for reading.
Shaun
    Dec 22, 2006
    Jul 17, 2011 4:33 PM (in response to sketterman)
    Re: Cannot Updated Flash Memory on POD XT
    try a different usb port, this should re-initialize the driver.
  • Anse Just Startin' 26 posts since
    Sep 5, 2008
    Jul 18, 2011 4:21 AM (in response to sketterman)
    I very recently experienced the same problem.This was solved by an uninstall of Line 6 Edit ,clean up of the registry (I use a freeware program called Crap Cleaner) and then a reinstall.
    I still have problems with digital artifacts (like a strange language in the background of the forum screens) and also Line 6 Edit and Gearbox crashing when rearranging and transferring tones.
    I am able to use my XT just fine,seems to be a Windows 64 bit issue.
    If I recall correctly you must recieve a support ticket for direct help from Line 6,and I wouldnt hold my breath.Try cleaning your registry with one of the free programs available.Hope I was of assistance.
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    Jul 22, 2011 4:25 PM (in response to sketterman)
    RE: Cannot Updated Flash Memory on POD XT
    sketterman,
      I suggest putting the PODxt into SAFE MODE, then, attempt to re-install or update the flash memory on the PODxt.
      This can be done by holding the first of the 4 soft black buttons under the LCD screen (leftmost) as you power on the PODxt.  The display should read SAFE MODE.
      Once in this mode, connect to Line 6 Monkey and check to see if you can update or re-install the flash memory.
      If the problem persist, I suggest trying on a different computer to isolate the problem.
      Regards,
      Line6Hugo
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
