1571 Views 6 Replies Latest reply: Jul 27, 2011 5:59 PM by amx05462 RSS
hserio Just Startin' 10 posts since
Nov 30, 2010
Jul 27, 2011 9:45 AM
Nut for Variax
I love my variax 700.
But the nut sucks big time.
It doesn't keep the strings in tune when I use the tremolo bar.
I recently found that there's a graphtech nut specially designed to prevent that.
And I need the nut measures to buy a compatible nut.
Since I'm changing the nut for my electric vafiax 700, I'll do the same with my variax 700 acoustic steel.
I'm From Brazil, and the standard measures here are different, so I can't figure that out for myself.
So, can anyone help me with this?
The measures for both nuts, or the compatible models of graphtech nuts?
Thanks.
    Dec 22, 2006
    Jul 27, 2011 10:03 AM (in response to hserio)
    Re: Nut for Variax
    i would just get in touch with graphtec directly: http://www.graphtech.com/contact.html
    they are very helpful and will know the exact product you need.
    • amx05462 Power User 3,495 posts since
      Sep 1, 2008
      Jul 27, 2011 11:43 AM (in response to TheRealZap)
      Re: Nut for Variax
      i believe  a fender  strat  or telecaster  nut  will do the trick.
         what may be  better  than  the graphtech one  is a fender  roller  nut.  but theres a bit more  to installing  them.  the   good thing  is  the  strings  move  on   ball bearings.    ive got one  on my strat.   it  was a big help.
      http://cgi.ebay.com/Fender-LSR-Roller-Nut-1-11-16-Chrome-099-0812-000-/140572190107?pt=Guitar_Accessories&hash=item20bac1659b
      you casn check one  out  here
      • JellyWheat Gear Head 1,220 posts since
        Aug 18, 2008
        Jul 27, 2011 3:46 PM (in response to amx05462)
        Re: Nut for Variax
        I hate to rain on the parade here, O Great One, but I believe a Fender roller nut requires a slot in the fingerboard. It will not butt up against the trimmed end of a Gibson-type fingerboard unless raised to the correct level relative to the surface of the fingerboard by means odf a block.
        There are products like Mighty Mite roller nuts specifically made for this type of application (Gibson-style nut replacement), but you would have to do some woodwork to get the Fender roller nut to do the job on the Variax 700 electric.
        Line6Antonio may choose to correct me on this, but I am pretty certain that I speak the truth! Sorry to be disagreeable, Your Eminence!
        [... does this mean you are going to pee in my hat again, Excellency?]
        (8>c}... damn! It takes DAYS for that felt to dry!
        J/W
        [Oh, and by the way: although the Graphtech products are super quality, they will not entirely solve the problem unless the string grooves are properly cut. I never experienced any nut binding problems with my Variax 700 electric with the stock Corian nut, for whatever that is worth.]
          Sep 1, 2008
          Jul 27, 2011 5:45 PM (in response to JellyWheat)
          Re: Nut for Variax
          yes  you are  correct  sir.  they came  up with a soloution.fender_lsr_roller-nut_all.jpg
          what you do is  put this  on wether it  be  fender  or  gibson instalation.  its  not a drop in item in either  case  . for that matter  neither is  mity might. i have  a mighty mite  on my wild kat.  neither  is an easy job.  both  are a great improvement  over  a standard  nut when  using a tremelo  . mity might is tougher to put in..
            having done both  and  used  both i prefer the fender  nut. just  my opinion.CIMG2096.JPG
          both require  some  wood  work.  on the  fender  you  remove the  slot  on one  side.   the mighty might   also requires  wood  work as it sits  way too tall from the  factory  because of its  frame.
          in either  case  as you said  it  has to be put at the  right  level.to the  frets.
          ast to the  line  6  nut.  i had a hard tail  300 so i couldnt say if  it  binded  or not. but  it  wouldnt  surprise me if  some did.
          so put that  hat  outside  to dry and  air  out a bit cause  i took some  vitamins  and   you know what that does to yer  pee. lol
