6775 Views 7 Replies Latest reply: Mar 21, 2010 2:22 AM by hansibar RSS
d3drocks Just Startin' 86 posts since
Mar 9, 2007
May 2, 2009 7:24 PM
Vyzex Editor doesnt see pocket pod at all.
ok,
SO i made a post in the pocket pod support earlier: http://line6.com/community/thread/6775?tstart=0
what has changed now is that I've tried pocket pod on my brother's PC, which does not have the same plug and play BS that this PC (my audio workstation) has.
I ran Vyzex Editor, and it could not detect the pocket pod. I made changes to the midi settings in the program, and selected the device it should be sending to, but nothing happend. I'm really starting to get aggrivated now. what is wrong?
EDIT: I also found some PDF with a guide on how to solve the issue. it didnt help at all. (i am also not going to edit my brother's registry. Ide only be willing to do that on this PC which just doesnt even seem to work plug and play. I'm beyond ****** right now.)
  • PsicraftTony Iknowathingortwo 243 posts since
    Jun 22, 2007
    May 3, 2009 12:03 PM (in response to d3drocks)
    Re: Vyzex Editor doesnt see pocket pod at all.
    I appreciate your frustration, but you should direct it at Microsoft and USB peripheral manufacturers whose drivers interfere with the class compliant MIDI driver supplied with Windows.
    Every audio product manufacturer has to deal with this issue cropping up on certain PCs with certain USB webcams and mice installed - This issue is not the result of a Line 6 hardware or Psicraft software fault, which is why the best we can do is provide the troubleshooting PDF you downloaded.
    The registry fix described in the PDF has been proven to work in most cases where a logitech driver is to blame, incidentally.
    Tony
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
