849 Views 4 Replies Latest reply: Aug 12, 2011 6:58 PM by killaken2000 RSS
orbital Just Startin' 3 posts since
Oct 2, 2007
Aug 2, 2011 12:12 PM
All I wanna do is turn the wah on and off!
Brand new POD HD (Black desktop model). FBV Express. I only bought the thing so I could access some wahs for recording. I don't need it for live.
The wahs sound great. Trouble is, when I tilt forward and "click" the wah off, the FBV switches to volume pedal and leaves the wah on (wide open in it's last position).
Something I'm missing? Thanks in advance.
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Aug 3, 2011 11:33 AM (in response to orbital)
    Re: RE: All I wanna do is turn the wah on and off!
    The Wah needs to be set the the inverse "state" as the Volume.  In other words, if you're looking at the device icons display, when the Volume icon is not shaded it will be "on" but if the Wah is also not shaded it too is on. To inverse the state of bypass (shaded), put the arrow over the Wah and press "Enter" to bypass while the FBV is in "Vol" control state.
    Save the program on your POD HD. Did this help?
  • Line6Don Line 6 Support 5,275 posts since
    Mar 14, 2011
    Aug 8, 2011 10:18 AM (in response to orbital)
    Hey orbital,
      For each preset that you would like to use the WAH on please try the following configurations:
      -Add the Wah model you would like to use.
      -Select the Wah's FX block within the signal flow view.
      -Press and hold the "Enter" button, this should engage FS assign view.
      -Use the first encoder knob to assign the wah to "EXP Toe Switch".
      -Press the View button once you are done to exit.
      -With the Wah FX block still selected, double press the Move button to enter the controller assign. Assign it to EXP 2 then back to EXP1.
      This should allow to use the expression pedal as the wah and click it down to turn it off.
      If you set it up for EXP 2, you can click on the wah to engage and disengage it.
  • killaken2000 Just Startin' 1 posts since
    Aug 12, 2011
    Aug 12, 2011 6:58 PM (in response to orbital)
    Re: All I wanna do is turn the wah on and off!
    thanks line6don that helped me a bunch also
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
