1039 Views 4 Replies Latest reply: Aug 21, 2011 5:50 PM by Manstone RSS
Manstone Just Startin' 20 posts since
Apr 13, 2010
Aug 19, 2011 5:49 PM
wah problem on pod HD 500 ?
i have recently bought the hd 500, mostly as a unit to record with, as it pretty much nails the tone that i use live with a Mesa rectifier boosted by a Tubescreamer.
       When adding the wah though, i have noticed that it considerably reduces the gain produced by the Tubescramer or "screamer" model as it is named, but doesn't affect amp gain/distortion on the Mesa "Treadplate" model.
This is happening even when the wah is switched off too !!!........i have tried placing the wah before and after the screamer but to no avail...all the wah models appear to do this on the HD 500.
              I will carry on using my own wah in front of the HD 500 (though shouldn't have to really) as i also find that you have to hit a foot switch to activate the wah, rather than just treading on the wah pedal to switch it on like any real wah, which is kind of annoying.
   any body else come across this ?
    Mar 26, 2007
    Aug 19, 2011 9:05 PM (in response to Manstone)
    Re: wah problem on pod HD 500 ?
    I nearly always place a Wah in the OFF position before a Screamer in my signal chain, but have to say I've never noticed any tone sucking such as you're describing.
    What firmware version are you running in your POD?  When you last updated your POD's firmware did you clear the unit's Global Parameter settings by holding down the left button on the 4 way Nav pad?  This won't delete your presets, but it will set all global parameters back to factory defaults including Set List names and you will need to recalibrate your unit's expression pedal.
    Also, check your POD's input configuration for the presets you're having trouble with.
    What guitar are you using when you notice this problem?
    Is your POD HD500 connected to a computer when this issue occurs?
    Can you post an example of a preset that demonstrates the issue please?
    Nick
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
