2029 Views 9 Replies Latest reply: Sep 10, 2011 4:57 AM by Nick_Mattocks RSS
jesuscares Just Startin' 240 posts since
Feb 3, 2007
Sep 7, 2011 12:21 AM
Disconnecting speakers...
How do I disconnect the speakers from the amp on m Mk2 amp? Is it ok to disconnect speakers & use just the amp section for line out recording?
  • SSstormtrooper Just Startin' 94 posts since
    Jan 19, 2011
    Sep 7, 2011 2:10 AM (in response to jesuscares)
    Re: Disconnecting speakers...
    Leave it in standby mode and hook up the xlr out to your mixer or audio interface and there you go.Make sure to set your DI output to "Studio" mode and don't bump the standby switch by accident.
    *Never run any tube amp with the speakers disconnected! The electricity created needs to go somewhere and it is drained into the speakers.You could seriously damage your amp by trying to run it with no speaker load.
    I have the SpiderValve mkii HD 100 head and have read to never run it with out a cabinet(speaker load) or there will be serious damage.There is a cheat if people so wish but be fore warned about the dangers.One can put the amp in standby mode and run it with no speaker load because the power output tubes aren't on and only the pre-amp tubes are fired up,but....one false move by you,little kids or a dog or something bumping that switch out of standby mode and your amp is frazzled.So I suggest always keeping speakers or a "hot plate" connected at all times.
    A Line 6 expert can tell you for sure but for now I'd stick to what I'm saying
  • spaceatl Expert Line 6 User 4,456 posts since
    Jan 24, 2007
    Sep 7, 2011 5:51 PM (in response to jesuscares)
    In theory, leaving it on standby should not damage it...However, if the switch ever got bumped without a load attached you could blow the output tranny...And when an output tranny goes, it almost always takes something else with it...You could be lucky if the fuses blew in time I think...
    You could pull the power amp fuse...Likely, this would disabled the power amp completely, but likely the heaters would still be burning since that fuse is internal...
    Another way to protect yourself is to just remove the tubes...The amp is not likely designed to run like that, but is likely safer than running with no load at all...
    Personally, I won't run a tube amp without a load attached...One thing you could use a dummy load...basically, this is what those fancy annodized boxes that cost too much contain...But this is more like what a tech uses on a bench...
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=019-020
        Jan 24, 2007
        Sep 8, 2011 9:12 AM (in response to jesuscares)
        MK2 will send XLR direct in standby...You have to set that as there are two flavors of direct on MK2...If it is Live Mode then it pulls off the output tranny and tracks to the Master volume...You can run direct in stanby with a MK2 and a Mk1 (non SVPre mod)...What's the problem?
        You don't need a direct box...just punch into the snake directly with an XLR cable...Message was edited by: spaceatl
  • Line6Don Line 6 Support 5,274 posts since
    Mar 14, 2011
    Sep 8, 2011 2:08 PM (in response to jesuscares)
    RE: Disconnecting speakers...
    Hey jesuscares,
      I would suggest to use the Direct Out XLR output for home recording.
      I would suggest to use the live mode for the Direct Out so that it can take advantage of the Power amp's tone. Make sure not to disconnect any of the speaker leads. I would say you could take the amp out of standby and keep it at a low volume so that the amp can be used to monitor your sound, try to use as much master volume as you can.
      For more information on how to adjust the Direct Output modes, reference page 3-4 of the Spider Valve MKII Advanced Users guide at the link below:
      http://l6c.scdn.line6.net/data/l/0a060072bd264aca7babf058d/application/pdf/Spider%20Valve%20MkII%20Advanced%20Guide%20(Rev%20A)%20-%20English.pdf
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
