1141 Views 9 Replies Latest reply: Dec 23, 2012 8:42 PM by BlueViolince RSS
RhelmTrent Just Startin' 9 posts since
Aug 24, 2011
Sep 10, 2011 10:50 AM
Using HD500 for reamping...is it possible?
I recently viewed a video that displayed how you could record a guitar track to a DAW and hear the processed signal but the DAW would only record the dry track which could be processed by another amp sim plugin...etc
I would really like to be able to do this with the HD500 but maybe a little differently:
I would like to setup a cool HD500 patch and have that sound record directly to channel 1 in my DAW and also have track 2 setup to receive the dry track at the same time.
The only way I could perceive to do this would be to plug the guitar into a reamp box and send one input to the HD500 and take the SPDIF signal output and plug it to the SPDIF digital input on a separate A/D device that would be connected to the computer and take the output from the reamp box and plug into the A/D device. This appears to be a way to do it but the bummer is that I don't have the money for a reamp box or a new A/D device.
Any thoughts guys?
BTW: my end-goal is to have a stereo track of HD500 on track 1 and a dry signal on track 2 so that I can use my amp sims and IRs.
  • silverhead Expert Line 6 User 9,592 posts since
    Apr 1, 2009
    Sep 10, 2011 11:01 AM (in response to RhelmTrent)
    Re: Using HD500 for reamping...is it possible?
    You can use only the HD500 to do this with two important restrictions: the wet track you want to record from the HD500 must use only one amp, and it must be a mono output - no dual amps, no stereo.
    With those restrictions you can make use of the HD500 dual path feature to send both wet and dry signals seperately, in mono, to your PC over the usb connection. To do this, split your paths immediately in the HD500 signal chain for the patch/preset. Put your amp and all FX in one path. Put nothing in the other path (the dry signal). In the mixer, pan your two paths full L and full R. When you arm the tracks for recording in your DAW, select the L channel for one track and the R channel for the other.
    • relayerjb Just Startin' 90 posts since
      Aug 8, 2011
      Sep 10, 2011 11:34 AM (in response to silverhead)
      If your DAW will let you run a line out back to the HD, you could also put the HD's FX Loop as the first effect in your signal chain.  Run the output of the Loop to your DAW and record the dry signal.  Run the return line from the DAW to the input of the FX Loop.  The signal then goes thru your HD500 and you can process it however you want, including using two amps, stereo, whatever.  Then run the regular outputs from the HD back into another channel on your DAW.  (Make sure that only the dry signal from the FX Loop is sent back from the DAW to the HD, not the processed signal) ...
  • bjnette Just Startin' 82 posts since
    Sep 2, 2012
    Dec 9, 2012 7:15 AM (in response to RhelmTrent)
    Or you can set the s/pdif out to dry and record a dry track via s/pdif in on your soundcard or interface.
    The question is, can you come out of your DAW into the 500 and use the unit to reamp the dry recorded tracks?
      Sep 2, 2012
      Dec 9, 2012 8:57 PM (in response to bjnette)
      I know this is an old thread but I too have some questions.
      I know Frasctal's AxeII can be used to reamp a DAW dry track.
      I like lots of tone and some FX when tracking so am outputting the s/pdif outs dry into Sonar X2.but monitoring the analogue processed outs on my HD 500
      Reamping into the HD
      On the HDs can the input impedence adjustment page match impedience  to accept a line level.? I am about to try this out tonight.
      Is anyone reamping with a reverse DI into the HDs.
      Lastly, while using the dual chanells in the POD is one way, I beeieve that with my MOTU2408mkIII I can select the dry to it's own output to the HD and use the any output from the HD back in to the Motu into the DAW where only the reamped tone is monitored. Some slight time line adjustment may also be needed.
      Anone using  it to reamp to?
      I suspect that a reverse DI might still be required.
      Tonight will soon tell
    • unperfectcircle Just Startin' 16 posts since
      Sep 17, 2012
      Dec 22, 2012 5:56 AM (in response to bjnette)
      +1
      I'm interested in this issue too.
      I tried to reamp a dry signal coming from my DAW into the HD500, but it seems like the signal is always a bit noisier than the one I get coming directly from my guitar (with the same POD settings, of course).
      I used both guitar and aux ins, Variax on Input 2, but I was only able to tame that "background" noise.
      Could it be an impedance matching problem?
      Have anyone had positive results reamping a dry signal from DAW into the POD HD500?
      • BlueViolince Just Startin' 55 posts since
        Dec 15, 2008
        Dec 23, 2012 8:42 PM (in response to unperfectcircle)
        I've done that in Pro Tools 10.  I track dry, with a bit of verb on the monitors.  Then, I set up a hardware send, switch the POD to Line output, and track the outputs to a stereo track.  You could technically do this with a dry track recorded through the POD only, but that would involve using your computer's 1/8" output to get back into the POD, which I have never tried to do.  Depends on the quality of your sound card.  If you had to, you could use a noise gate/duck on the processed signal.  I would recommend turning off any delay or reverb on the POD in favor of software plugins placed after the gate.  That would reduce some of the noise without cutting off your repeats and decay.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
