Sep 11, 2011 12:03 PM
Variax Footswitch with Passive Guitar
Like (0)
Can I use the powered footswitch as an A/B box with a standard passive guitar if I use a mono TS cable? The power light is off when switched to the 1/4" output, but lights up red when switched to XLR. Is this safe to do for the guitar, footswitch and amp?
i suppose you could it is a switch. why would you use it powered?
The switch doesn't work without power. Also, the power light only glows red for a few seconds, then goes off, so I assume that means that no power is being transmitted.
i think your assuming wrong. the power goes through the tip to the center sleeve as ground on a trs cable since your putting a mono cable in your creating a circut that wasnt originally there your attatched to the ground terminal and at the same time the terminal that the sound circut connects to. so technichly your creating a short with the mono cable and thats probably why the red light goes off. is it gonna damage your guitar. most likely not but ill bet your sending current to the guitar through the pots and pickups. heres how to find out . hook up a meter to the mono cable that plugs into the guitar tip to shank. if your getting power there well then you have completed a circut. since the ab box is designed to do this . well is it working correctly. if not it may be shorting internally and who knows what that will do over time. since these switches arent readily avalable... do you want to take that chance is the question. you might fry a resistor over time. i dont see these avalable anywhere.
as to the amp end it wasnt designed to sent power to the amp as far as i know . so that end should be fine. if you feel you need to do this with this ab switch with another guitar that does not require power id say stick with the stereo cable. in most cases the contact in the guitar if you have a good output plug is low on the shank and the tip. the trs should work fine. ive used them this whay when i diidnt have anything else with no problems.
my advice to you would be to not use this switch in that way. go buy one or build one. just curious what are you trying to acomplish with that rig.
i would suggest you get one of these. its cheaper than the line 6 switch and you can get these . like i said the line 6 switch is not readily avalable.
(8>*} ... I will include a question on this in the new edition of the VOQT™ I am currently working on, O Great, All-Knowing One!
J/W
voqt wat dat?
Variax Owners' Qualification Test
J/W
oh oh im in trouble.
(8>ɔ)... Not at all, Excellency. You are endowed with a great deal of "horse sense", being - like myself - a type of horse's a$... OOPS! Damned typos!
Ahem!... Nothing to fear from this little test, Sire. It's just the same principle as not selling guns to...
I am sure you would pass with flying colors!
J/W
why thankyou . i thought playing one without a proper set of paperwork could get me in a big jam at l6... thats good to know.
i see this thread is still marked unanswered. would the miracle answer man please stand up
Hey, hey, amx05462
We have to wait for 48 hours without activity from the original poster before "The Eraser' swoops in and delivers the coup de grace...
J/W
[Do you see now why it is a good thing we were never in the same class in high school?]
i can see clearly now. we refer to that person as the eraser here...
I have corrected my erroneous post, Excellence... please forgive me!
J/W
So, should I use the stereo TRS cable?
uh no you should get a proper ab box. the line 6 one was only meant to be used with line 6 guitars. ... in my opinion.
Thank you very much. Looks like I've got a new DIY project!
