Currently Being ModeratedRe: Pod HD High Gain Tone Guide
Excellent Stuff...You have a heart to do this for others you dont know.
Thanks, Pratik
- Report Abuse
Like (0)
I used bullzip PDF printer, it's free, download from http://www.bullzip.com/download.php
Once installed, just print the .doc and select bullzip PDF printer instead of your regular printer.
- Report Abuse
Like (0)
Great stuff, thanks!
- Report Abuse
Like (0)
Meambobbo, Very nicely done dude. I downloaded it, i'm reading and taking it all in. i thank you for it to as we all seem to be doing. Can't wait to try out some of your custome tone patch files once you get the chance to upload. But for now take a breather and take in the internet round of applause for a job well done.
Peace
Jer
- Report Abuse
Like (0)
Thanks for folks like you... this is really a great guide in general and is very useful in understanding setup with the HD 500. Thanks a lot ofr making this guide, just great!
I already used some of the info to do my first POD HD 500 video.
- Report Abuse
Like (0)
A massive effort massively appreciated! If only there were more people happy to share knowledge like this....
This post should be linked somewhere on the site as a "must read" before newbs starting to ask the same questions time and time again. In fact I reckon just about every guitarist visiting the site could learn something to help them on the road to improving understanding of "tone" and how to get closer to the sound you're looking for.
Thanks meambobbo for all your effort and for sharing!
- Report Abuse
Like (0)
Hey I've had some requests to link to the guide from other sites, etc. I just wanted everyone to know that's perfectly fine. I'm not looking for credit or anything like that.
You can even edit the doc and repost it if you want. Just please make a note in the beginning of the document that it is an edited version. And please make a post in this thread letting people know if you have something to add or believe there's an error in the document.
- Report Abuse
Like (0)
yes - using a bit of drive will get you compression before distortion on the "distortion" effects. as far as compensating volume, you may or may not have to - it will depend on how much pickup output your guitar has. my advice is to turn off the amp model, and dial in the amount of compression you want with ONLY the distortion effect on. then toggle it on and off, comparing the volume level, and adjust it until it is basically volume neutral. then turn your amp model back on and dial in your tone.
awesome name by the way - can't wait for grace for drowning!
- Report Abuse
Like (0)
Great read, thanks for sharing. The HD500 is great for high gain tone, I use an HD500 and Rocktron Velocity 300 for my metal bands
www.facebook.com/molesettheepiscopate All songs recorded here were with the HD500.
and
www.facebook.com/indreadresponse
- Report Abuse
Like (1)
cheers for the info mb.
yup.......Grace for Drowning should be pretty cool, judging by the few clips posted on the GfD mini-site.Much as I love the Prog/Metal stuff Wilson does in "the 'Tree" i really dig his more ambient and experimental solo stuff (also the Blackfield stuff too)
- Report Abuse
Like (0)
i agree - insurgentes was his best album, imo. and don't forget no-man!
- Report Abuse
Like (0)
Here's another vote for the more ambient stuff...
- Report Abuse
Like (0)
I have made a webpage with sample clips and patches attempting to somewhat emualate some metal/shred artists. Some are a lot closer to the actual artist's tone than others. I really just wanted to use all the amps and demo some of my tone-building techniques referenced in the guide.
- Report Abuse
Like (0)
Thx a lot ! Will try them as soon as possible. What guitars/pickups did you use for the samples ?
BTW you might want to have a look at this page:
Tutorials and tips / Getting metal tones out of Line6's POD HD500
http://www.infinitefiremusic.com/tutorials_61668.html
These are tips at how to use double amps for metal tones.
- Report Abuse
Like (1)
for the rhythm tracks in E or drop D, I used my EBMM John Petrucci signature. It's the first model, which had Dimarzio pickups. I think they're custom, but people said the bridge humbucker is most similar to a Steve's Special. I don't use the neck pickup at all.
for the ones in B or drop Ab, I use a Yamaha Pacifica with a Seymour Duncan AHB-1 Bridge Blackouts humbucker. I have the heavier strings from a set of 7 strings on them - I think it's .013-.058.
for the lead clips, I use a custom guitar I've been building - custom-made Jem body with an RG neck and AHB-1 Blackouts pickups. I put the neck pickup in the neck position, bridge in bridge.
I checked out that guy's dual amps tips. There is one suggestion that I really like, which is setting one amp to your desired tone, and one amp to "amp disabled", then blend them so that you get a little more definition to your tone. I'm not sure why I never thought of that - I don't think it involves any DSP cost, like dual amps usually do. One guy used to always tell me how much better a distorted tone will sound if you blend in some clean guitar just a bit. To be honest, I don't think I ever tried it to the point where I can make a firm conclusion on it.
The other suggestions I find I more-or-less covered in the guide. You can get good sounds from them if you make a completely stereo patch, but for live use, if you have to go into a mono track on the mixing board, you're screwed, and if you want to record, why not record each amp as a separate track? I find the upside is quite limited while the DSP trade-off is huge - it's simply not worth it IMO.
- Report Abuse
Like (0)
Actions
- Retrieving data ...
Incoming Links
About
Follow
Subscribe
