341 Views 2 Replies Latest reply: Oct 14, 2011 12:15 PM by Tord RSS
Tord Just Startin' 8 posts since
Jun 17, 2007
Oct 12, 2011 9:19 AM
Total controll and recall ?
I just love the sounds of my Dt 50 all opf the preamptube configurations sounds superb with the powertubes, but the noise it generates without even turning the volym up is a little bit anoying, ill guess it can be removed with a noise suppressor in the send return loop?
I wished they hade made a Midi floorboard with the the effect section implanted so you could get to change topology and settings of the amp and also controll the the effect section with midi at the same time, effects like those in the M13 or the same packege as in HD500.
Because of what i heard so far the hd 500preamp sounds dont seam to have the same bite in the sound as the tube preamp by it self.
And ill guess thats because it is totally bypassed and the HD500 goes directly to the power amp.
I have a X3 live and i have owened many pod since they appeared in the market I, II, Xt to name them andi have allways missed that little extra crisp or bite,
Call it what you want that you get out of a real tube so with my latest the x3 i have a Blue tube from tube works in the loop and that made all the difference.
Works super in my home studio but live hmm
it is something with the pods the sound like they have a compressor activated even when you have turn all those effects of.
And it seams to me that it would bequite owerworked to have to add that to the loop chain of a Hd 500 when you connect it to a DT50 when the dt50 has a better one from the beginning.
Content : what i wanted was to controll the amp totally and a bunch of effects not a Pod Hd 500 that simmulates the topologys connected to a power amp.
Its a god Pod But the sounds is not as good as the DT50 by it self.
So have do i solve this problem without downgrade my self soundwise?
    Dec 22, 2006
    Oct 12, 2011 9:53 AM (in response to Tord)
    Re: Total controll and recall ?
    wow... you have some seriously wrong information there....
    -the bitrate/quality is the same for HD's and the DT's
    -the amp CAN be controlled by midi (although there are no effects in the amp to control except reverb)
    -some people who hear abnormally loud noise from the amp when quiet, have replaced the tubes and fixed the issue.
    the HD's do not "simulate topologies... unless you use the full models...
    the pre models that are designed to be used with the DT's control the amp and change the topology same as it does when you change it on the amp itself.
    i think you need to learn a few things about the equipment....
    no offense... we all have to learn it somehow and sometimes...
    but i really don't think that a single thing you said in your post was accurate.....
    again... not trying to be offensive or insulting... just trying to point you in the right direction.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
