Oct 13, 2011 3:08 PM
Pocket Pod to Amp-Problems.
Like (0)
Hey guys ,Just got My line 6 pocket pod....I connected the POD into my amp (Ibanez gta10 combo)and when i have effects such as delay reverb and chorus,I have this buzzing noise from my amp.The tone is kinda muddy.But when i connect it to the my speaker system I have no problems. Do i have to change settings on my amp?..I have problems mostly with the distorted metal tones.Should I put the amp on the clean setting...Or is there any other solution to it?Please,people,please i beg,do help me out here.
Cheers,
Arpith.
Yes, we always recommend that if you're going to run the output of an amp modelling device such as the Pocket POD into a real guitar amp that you set the guitar amp as "clean" as possible with no effects.
The output of the POD was intended to go into a mixing console/PA. If you have your real guitar amp set for high gain, you'll essentially be taking a modelled guitar amp signal and then feed into another guitar amp; if set with higher gain the noise floor will definitely go up and really amplify any other sounds/noise artifacts moreso.
Hey Arpith,
It has been at least 72 hours since we've heard from you. We're going to assume your question has been answered and close this thread. If you feel your question(s) have not been answered, or, if you have further questions, please feel free to re-open a support thread within our support community and we will answer your questions accordingly.
Thanks!
