502 Views 3 Replies Latest reply: Oct 21, 2011 1:53 AM by edstar1960 RSS
jsteenkolk Just Startin' 10 posts since
May 6, 2007
Oct 17, 2011 9:09 PM
Gearbox, Podx3 Live & JTV-69
I have been using Gearbox to program interface between my Podx3 Live and a Variax 700 using the digital interface cable.  I program Podx3 amp/effects patches and a particular guitar into the patch, save into a particular bank/channel, press the channel and presto I have my guitar/amp patch.  I use this to jump from acousitc to electric guitars, rythm to lead patches, etc.  Just got my new JTV-69.  No matter what I've tried, the JTV does not recognize the programmed guitar model within the patches.  Has any experienced the same issue?  Am I missing some new setting or mode I must be in?
  • edstar1960 Iknowathingortwo 712 posts since
    May 25, 2010
    Oct 18, 2011 1:52 AM (in response to jsteenkolk)
    Re: Gearbox, Podx3 Live & JTV-69
    I have an X3L, a Variax 700 and a JTV59. I have my X3L patches programmed to automatically change patches on my Variax 700.
    When I connected my JTV59 to my X3L with the VDI cable, I noticed that it would not change the guitar models with the patches, and when I reviewed the input settings I noticed that it had reverted back to DONT FORCE MODEL but that it did indicate it was connected to a JTV59 rather than a Variax 700.
    So, I simply changed the setting to Variax Control on the X3L, dialled in the correct model on my JTV59 and re-saved the patch on the X3L.  Then when I swapped to that X3L patch, it also swapped my JTV59 model.
    I then disconnected my JTV59, and re-connected my Variax 700, and discovered that the X3L still recalled the Variax 700 model setting for that patch.
    So - the X3L actually stores and recalls BOTH Variax 700 and JTV50 model settings for each patch.
    The only annoyance is you actually have to go through every X3L patch you use and set up the JTV59 model selection and save the patch again.   But it can be done very quickly - and once its done you don't need to do it again - so not too bad at all.
    Cheers
    Eddie
        May 25, 2010
        Oct 21, 2011 1:53 AM (in response to jsteenkolk)
        I hear you John.
        I didn't realise that the X3L does not copy the JTV patch info if you copy a patch, and unfortunately I don't use Gearbox very often, so I also didn't realise that the JTV info was not recognised in that - although I thought it allowed the choice of input channel for the JTV (CH1, CH2) but I may be wrong on that.
        I agree with your sentiments and think that while they were updating the X3L firmware to support the JTV that they could have made sure it supported it full (eg: copying the info) and that they should have updated Gearbox to keep it in step as that is the main tool for X3L users.  I can't imagine that it is a huge change so would not cost them much but the pay off from good will and satisfied customers would be immense and far outweigh any cost.
        Lets hope they make the change soon!
        Best Regards
        Eddie
