970 Views 19 Replies Latest reply: Aug 13, 2012 5:51 AM by Benni2407 RSS
edstar1960 Iknowathingortwo 712 posts since
May 25, 2010
Oct 20, 2011 8:18 AM
JTV operation with VDI and 1/4" jack connected at same time
Here is an official Line6 demo of the JTV69 from Paul Hindmarsh using VDI and 1/4" jack connected at the same time:
http://www.youtube.com/watch?v=meqkcELwew0&feature=related
I have seen many reports on the forums that using both VDI and 1/4" connections at the same time is not viable because you get ground loop problems and other high pitched noises.  I have also tried doing the same thing with my JTV59 and encountered a ground loop issue and a high pitched whine. I have also seen reports that Line6's official response is that the guitar is working as designed when it encounters these issues.
So please can we have a detailed description of the rig and connection's that Paul used during this video that avoided all of these reported issues and allowed him to have both the VDI and 1/4" jack connections connected at the same time.  I am sure many people would be interested to know how they can circumvent this problem.
Thank you.
    Dec 22, 2006
    just curious...
    why would you want both connected at the same time anyway?
        Dec 22, 2006
        i went to one of pauls demo's in person and i don't think that the intent was anything to do with utilizing both connections simultaneously... more that he builds on each component...
        first showing the guitar itself and eventually showing the whole "dream rig" by including all of the patches tones etc of the pod and then the DT50 topologies etc.
        i'm not saying you couldn't get creative and run it to multiple processors etc... (as long as one is an L6 due to the VDI)
        was just curious is all, i suppose....
    • m1westwood Just Startin' 3 posts since
      Jan 13, 2012
      RealZap,
      I use a Digitech Vocalist live 4 for Harmonies, and I need to run my guitar though that.  I am thinking the best way to do this would be to use two cables; the VDI cable to my hd500 and the 1/4 inch cable to my VL4.  Have not tried it yet, but this is why I would want to use both cables.  Unless - someone else can tell me how to get a clean (effects free) signal by going VDI through the hd500 and then out from there to my VL4.
      Thoguhts?
      • Iknowathingortwo 1,667 posts since
        Jul 17, 2007
        Yes - you could do exactly that and it would work or...
        You could use the FX loop Send Only into your Vocalist to get the guitar chords for pitch tuning without using two chords or disrupting your signal path and VDI connection.  You don't need the signal to come back out of the Vocalist, just in for your harmonies.
        And I had to re-read your question - the second part..FX free, that will be based on where in the signal chain you put the FX loop send.  If you put it at the top of the signal chain or even after a noise gate, it would not have any FX after the loop send as you wanted.
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    edstar1960,
      In the video's comments, Paul's says, "that would have been acoustics straight into the PA and electrics into POD HD500 and DT50."
      Using both outputs on the JTV's typically yields the ground loop noise you mentioned.  Using a D.I. box with a ground lift or a Ground Loop Eliminator box would need to be used to eliminate this problem.
      Regards,
      Line6Hugo
        • Benni2407 Just Startin' 55 posts since
          Dec 22, 2008
          Hello,
          I am responding to this old thread, because it adresses my actual problem pretty well. I want to use the following setup:
          Both (VDI and 1/4") outputs of the JTV-59. VDI should go to POD X3 Live for acoustic sounds and 1/4" output should feed my Combo. I get am big noise/hum problem with that configuration.
          Now I thought of putting a DI-Box with Ground Lift in the line from 1/4" jack of the JTV to the combo. But I do not really understand how to do this. If I got it right, the signal coming out of the DI is symmetric, isn't it? Can I feed my combo with a symmetric signal? I guess I can't. So what to to? I would be really glad to have your help!
          Thanks in advance,
          Benni
              Dec 22, 2008
              Hi Eddie,
              many thanks for your fast reply! Yes, I mean balanced. Sorry for my English... In German the right word is "symmetrisch" so I thought it might also be called "symmetric" in Englisch.
              I'm going to try the adaptor-version. I just found out, that there are ground loop eliminators, that work with 1/4" jacks as input and output. Maybe thats another solution. For example the ART Cleanbox II.
              The thing why I don't want to swap VDI and 1/4" is, that the POD gives best acoustic sounds and my amp makes brilliant sounds, when there is no POD before it. Actually I have the POD in the amp's loop, to get delays etc. from the POD. When I switch to the acoustic preset on the POD, the POD's loop is turned off and and output is sent to the direct outs instead of the live out, where the amp's loop is connected.
              That is really complicated, but it would give the best results for me, if I could get rid of that noise.
              Thanks again,
              Benni
                Dec 22, 2008
                Hi Eddie,
                thank you for your commendation! I'll do my best to get the hum problem mastered! For sure I will post my solution here if I am able to figure out a way to satisfactory solve it.
                Best regards,
                Benni
                  Dec 22, 2008
                  Hello,
                  I have figured out a solution for my hum problem now. I bought a ground loop eliminator, that has two seperate channels (Behringer HD400). This gound loop eliminator is put both in the line from the amp's fx-send to POD's aux and in the line from POD's live out to the amp's fx-return. Doing this, the POD is completely separated from the amp, which solves the hum problem.
                  Another way would be to put the ground loop eliminator in the line from the guitar to the amp's input. This also works, but I tend to hear a little less punch in the sound then.
                  Maybe this helps people, who would like to play the same setup, that I do. It's really flexible now!
                  regards,
                  Benni
  • cajulian Just Startin' 6 posts since
    Aug 4, 2011
    I have been using my JTV69 thru a HD500 to DT25 Head and cabinet, and connected to my PA.  I Have been using both the VDI cable for electric to my DT25 and the 1/4 cable for acoustics to my PA.  I do get a high pitch/hum initially, but I go to my Hd500 and switch the input source to either Variax or Guitar and it eliminates the noise and I can play either the electric or the acoustics with no interference.  It works like this every time I have both cables in use.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
